R
robertw007
replied to the thread
69' Whaler Nauset
Not totally wag, educated estimate 😂. It's a small console made of fiberglass. I figured even if it weighs 50lb itself. I'm still fairly...
Aug 19, 2025
R
1995 Evinrude E90TLEO charging
The stator to ground should read INFINITY.-----400 ohm indicates a short to ground.----Replace stator.
Aug 19, 2025
M
MikeSchinlaub
boat snap on covers
You'll have to take your boat to an upholstery shop and have one made. As someone who fixes boats, but doesn't own one, I suggest a...
Aug 19, 2025
M
MikeSchinlaub
reacted to
carlos515's post
in the thread
Changing colour of gelcoat question
with
Like
I lifted the boat off the rollers, the rollers were indenting the hull. I think removing the wobblers and turn the trailer into a bunk...
Aug 19, 2025
K
kepruno
reacted to
Pmt133's post
in the thread
2005 4.3 liter Mercruiser ignition trouble
with
Like
You could check 12v into the ignition switch since you're losing it there. If the supply side of the switch is fine your problem is the...
Aug 19, 2025
L
Lpgc
posted the thread
1996 OMC Cobra (Ford 302 / VolvoSX collaboration) sometimes runs hot
in
OMC I/O & Inboard Engines & Outdrives
During light throttle / slow cruising (not on the plane) the engine temperature is OK but sometimes (not always) the temp soon creeps...
Aug 19, 2025
J
Jimwhall
posted the thread
boat snap on covers
in
Boat Topics and Questions (not engine topics)
Specifically, the cover for the bow and separate cover for the passenger area (though they zip together). Are these nearly impossible to...
Aug 19, 2025
wvmedic
So did I interpret the above spec wrong in the .07 to 0.05? Should that be .07 +/- 0.05? Also is the reason you say replace the...
Aug 19, 2025
tpenfield
I Got Me a Mercury !!!
The '72 Mercury has now taken over the dinghy operations. The engine is running well. . . I brought the Evinrude back to the house and...
Aug 19, 2025
dingbat
Nice fish
Guessing commercial guys given bluefin are off-limits to us recs since August 12
Aug 19, 2025
redneck joe
69' Whaler Nauset
You are babbling, it's ok. New boat babbling is always ok. So do you have the console to weigh or were you just taking a WAG?
Aug 19, 2025
redneck joe
Trail camera issues fixed, now pics from them ...
We got a pair of what I would guess are two year old, what little I know . Look like 4 point but they stay on the far side of the field.
Aug 19, 2025
R
robertw007
reacted to
Scott Danforth's post
in the thread
69' Whaler Nauset
with
Like
continuous wave had a table that was closer to your reading, that was hull with console and listed dry weight at ~750 for the 16'-7"...
Aug 19, 2025
mr300z87
Milky oil from oil cooler failure
Thats the plan!!
Aug 19, 2025
WIMUSKY
Waiting for patterns to change or something, still little guys the few I see....
Aug 19, 2025
