FLATHEAD
reacted to
WIMUSKY's post
in the thread
Trail camera issues fixed, now pics from them ...
with
Like
Waiting for patterns to change or something, still little guys the few I see....
Aug 19, 2025
flyingscott
replied to the thread
cowl air inlet on mercury 9.9.
It is in the rear of the cowl by the grab handle. Or are you saying it does not run with the hood on?
Aug 19, 2025
C
cyclops222
reacted to
MikeSchinlaub's post
in the thread
69' Whaler Nauset
with
Like
You don't have time for small batches. If you try that, what's left if the first will kick in the gun before you get the second sprayed...
Aug 19, 2025
FLATHEAD
At first I thought this buck was already out of velvet, but nope still in velvet
Aug 19, 2025
FLATHEAD
Got this dirty girl showing off for the camera
Aug 19, 2025
WinnerCougar74
Reeds?
Using throttle while the motor was warm helped a little bit not much. I think I will have to either accept that it's gonna be a pain to...
Aug 19, 2025
C
cyclops222
2 stroke longevity?
Evinrude 1986 and a 1999 every May1 to Oct. 1 Every decent day. 50 and 100 to 1 ratios. Only Marine Hi Test.
Aug 19, 2025
T
TDAY44
posted the thread
1981 Johnson 115hp 4 cyl
in
Johnson & Evinrude Outboards
I have been working on a 1981 Johnson 115hp 4 cyl motor since winter, it has a problem with power cutting out intermittently. It will...
Aug 19, 2025
C
cyclops222
reacted to
dingbat's post
in the thread
2 stroke longevity?
with
Like
If 2S are only good for 10 years, I sure got my money worth out of the 1990 3pg Robbins motor in my golf cart. Runs on 128:1 fuel with a...
Aug 19, 2025
Scott06
Prop change on my bowrider
The spitfire doesnt have much bite in my experience. I get the same WOT rpm with a 23" spitfire as I do a 21" revolution 4. there is...
Aug 19, 2025
Scott06
As others have mentioned is the tach accurate? Are you able to hit the rev limiter which should kick in around 5050-5100 rpm. If you...
Aug 19, 2025
88 Capri (2022 SOTY)
File uploads no good again?
Thank you!
Aug 19, 2025
reacted to
BWR1953's post
in the thread
with
Like
Aug 19, 2025
wvmedic
1995 Evinrude E90TLEO charging
Thank you racerone. Jeff
Aug 19, 2025
H
highpowerdad
posted the thread
Steering at low speeds - Volvo Penta
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
Volvo Penta 5.0GXI-E (2005) in a 20 ft fourwinns. ~250 hours fresh water... mostly SO, finally got the steering cable/actuator sorted...
Aug 19, 2025
