C
Crosbyman
replied to the thread
1995 Evinrude E90TLEO charging
when testing for grounds make certain all leads are disconnected from anything external
Aug 19, 2025
guy48065
Prop change on my bowrider
I've looked at used listings for those because they are the models suggested by the Mercury prop selector. Those models are probably too...
Aug 19, 2025
A
airshot
Nice fish
A beautiful fish !! If what they say on TV they are worth.....big $$$ there
Aug 19, 2025
A
airshot
cowl air inlet on mercury 9.9.
Where the grab handle is located, there should be an intake up near the top so water can't get in. Can be hard to see, check for...
Aug 19, 2025
C
Crosbyman
Thoughts on 90hp ETECH
my 2005 75hp kid brother twin of a 90 hp (same hardware) has been a dream machine for 20 years now. but.... these engine require...
Aug 19, 2025
A
airshot
1981 Johnson 115hp 4 cyl
Find a factory service manual for your motor, all that info and more will be in there. I buy one for every motor I buy, well worth the...
Aug 19, 2025
A
airshot
2 stroke longevity?
My cheap ole Poison blower is almost 15 years old and runs like a top as is my old McColough chain saw, that one is about 30 yrs...
Aug 19, 2025
A
airshot
reacted to
Scott Danforth's post
in the thread
2 stroke longevity?
with
Like
two strokes rarely wear out. most are murdered by people running straight gas in them, or they let them sit to the point of rust in the...
Aug 19, 2025
Scott06
yes when the Outboards get bigger the hub diameter is the same as stern drive props- you just need to make sure it fits an alpha one...
Aug 19, 2025
A
airshot
reacted to
racerone's post
in the thread
2 stroke longevity?
with
Like
Two strokes last a long time.----Most end up on the scrap heap because of mistreatment / mistakes made by owners.-----Ever see a jet...
Aug 19, 2025
A
airshot
reacted to
jimmbo's post
in the thread
with
Like
I would try a 3 blade 21. I suspect with the Gearing on a 4.3, it probably came with a 21, but the previous Owner wanted better Hole...
Aug 19, 2025
A
airshot
reacted to
Stinnett21's post
in the thread
with
Like
A 21 4 blade will behave like a 23 3 blade, probably too much. I'd try a 21 3 blade. But first, check your tach. I would not expect a...
Aug 19, 2025
A
airshot
boat snap on covers
Like everything else, what are you going to do with it and how long do you expect it to last ? Water tight or just to keep debris out ...
Aug 19, 2025
MyLord
On throttle up the engine dies
Fuel was in a 2 gallon jug , fresh 2 days old... I use a modified outboard hose to deliver direct to engine , later I switch it to main...
Aug 19, 2025
arks
2 stroke longevity?
I have a ‘97 Seadoo GTI (2 stroke) and a ‘85 Evinrude 25 (2 stroke). Both run fine- but, then again, I know how to care for them.
Aug 19, 2025
