C
cyclops222
replied to the thread
Faria instrument gauges are still available.
A I search.
Aug 19, 2025
P
Pmt133
reacted to
beta's post
in the thread
1995 Crownline 202BR Restore
with
Like
Got the transom cut out and glued using Titebond III. Based on the keyhole cutout, everything looks good. Did a dry fit and all looks...
Aug 19, 2025
P
Phillip_333
On throttle up the engine dies
it’s only dying when you shift it right? Does it die when you throttle up in neutral?
Aug 19, 2025
C
cyclops222
1975 Johnson 70hp
How much weight in the boat ? Where is it placed ?
Aug 19, 2025
C
cyclops222
Best Outboard Motor Brands for Reliability and Long-Term Use
Evinrude 2 strokes with hand mixing of gas and oil at 100 to 1 ratios. I have a fantastic old Evinrude Mechanic. Mechanics keep a...
Aug 19, 2025
S
SlipperyOar
1981 Springbok 18' Restoration/Renovation
Sub flooring beneath bow casting deck cut and fit into place. Gotta seal and paint the wood and will install once foam is under/around...
Aug 19, 2025
E
evantful
posted the thread
Alignment adjustment, witness marks
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
Howdy, replaced a Gimbal Bearing (Volvo OEM Part) for a TSK-B/DPS-B Transom/outdrive. Went to check the alignment with my alignment bar...
Aug 19, 2025
B
Boats Pal Marine
2003 YAMAHA 225HP 4S
The 2003 Yamaha 225HP Four-Stroke (F225) is a solid motor, but there are a few key points you should know about that year and model...
Aug 19, 2025
dolluper
2014 GMC Sierra AC
Before you start chasing your tail on this one check the EAT sensor...sometimes known as evaporator temperature sensor It's in...
Aug 19, 2025
B
Boats Pal Marine
2004 Mercury 115 2 stroke - oil injection block off plate
If you’re looking to block off the oil injection on a 2004 Mercury 115 2-stroke, you’ll need a simple oil injection block-off kit/plate...
Aug 19, 2025
B
Boats Pal Marine
posted the thread
in
Boat Topics and Questions (not engine topics)
Hi everyone, I’d like to get your opinions on outboard motor reliability. Over the years I’ve worked with brands like Yamaha, Mercury...
Aug 19, 2025
N
Neil1982
1975 Johnson 70hp
yes 17" prop. I can get 35MPH out of it if I set the trim rod up further but not in my regular running position.
Aug 19, 2025
guy48065
reacted to
alldodge's post
in the thread
What is this indicator? (2000 Bayliner)
with
Like
Found the manual https://archive.org/details/manualzilla-id-6970797/page/n3/mode/2up
Aug 19, 2025
guy48065
Thank you but that's a different model. Hopefully the instructions are similar across various models. The bigger challenge is to figure...
Aug 19, 2025
S
saltchuckmatt
250hp Evinrude tilt Guage not working
If it's working manually but not when your triming it...the orientation must be incorrect. Tucked up kinda high usually. They do get...
Aug 19, 2025
