A
airshot
replied to the thread
anc switch.
Acc is for accessories....on my boat, it turns on the radio.
Aug 20, 2025
Steering at low speeds - Volvo Penta
new pump (without reservoir) is under $50
Aug 20, 2025
T
trippledigitss
reacted to
ta79pr's post
in the thread
Volvo Penta exhaust riser
with
Like
To add to the puzzle, it appears Volvo was making some various configurations for the 3.0 during the 90s. Here is the color cooling...
Aug 20, 2025
wvmedic
1995 Evinrude E90TLEO charging
I ordered the stator as well as the rectifier/regulator today. I went with CDI over OEM. I hope that was a wise choice. Jeff
Aug 20, 2025
wvmedic
Crosbyman, thank you. I did do that. I guess I was a little confused about what was a high reading, being infinity or OL vs a low...
Aug 20, 2025
A
airshot
Best Outboard Motor Brands for Reliability and Long-Term Use
You will find your answer under the same heading as which vehicle is best, Ford, Chevy, Honda, GMC, etc etc....all luck and opinions......
Aug 20, 2025
BWR1953
reacted to
redneck joe's post
in the thread
Is A I a totally unreliable function ?
with
Like
As you sit and play on the web?
Aug 20, 2025
nola mike
What is this indicator? (2000 Bayliner)
https://manualzz.com/doc/22948514/standard-horizon-ds41bd-owner-manual ?
Aug 20, 2025
J
Jimwhall
anc switch.
I'm an idiot. It's the ACC not ANC.
Aug 20, 2025
J
Jimwhall
anc switch.
That's a separate switch actually. NAV/ANC. Up is anchor light, down is nav lights.
Aug 20, 2025
J
Jimwhall
reacted to
alldodge's post
in the thread
anc switch.
with
Like
ANC = Anchor light
Aug 20, 2025
F
Fj40fiji
I didn't want to restore this 1997 Islander this summer
*Whipple- F’n autocorrect.
Aug 20, 2025
Texasmark
2003 Mercury ELPTO won't rev above idle
You apparently have binding somewhere. Get a manual and do a "Link and sync" which sets up the carbs and the linkage to the throttle...
Aug 20, 2025
Texasmark
LOWER END OIL CHANGE
I always used a screwdriver sized to adequately fit the slot in the plug. Installed the new fiber washer and with two hands on the...
Aug 20, 2025
Texasmark
reacted to
Chris1956's post
in the thread
with
Like
You will want to install new fiber washers on the two plugs. Make 'em tightest as possible with a screwdriver. A couple of taps with...
Aug 20, 2025
