C
replied to the thread
LOWER END OIL CHANGE
Jeff, hence the use of the hand impact driver. You first make the screws as tight as possible with a screwdriver, then use the hand...
Aug 20, 2025
R
robinfla52
No black/yellow kill wire on 9.9. 4-stroke
Thanks
Aug 20, 2025
C
The maxrules site may have a wiring diagram for your motor.
Aug 20, 2025
M
mike_i
boat snap on covers
Also check out local canvas shops to have a custom fit cover made.
Aug 20, 2025
R
robinfla52
I see picture upload is fixed. Yay
Aug 20, 2025
R
robinfla52
posted the thread
in
Mercury & Mariner Outboards
I get no spark on 2005 Mercury 9.9 4-stroke.I was thinking disconnect kill wire but can't find it. Since picture upload is not...
Aug 20, 2025
J
Jeff J
I was just thinking about this. I have yet to see a screwdriver or bit that properly fits a lower unit pan head style drain plug. The...
Aug 20, 2025
BWR1953
reacted to
airshot's post
in the thread
Nobody fishing?
with
Like
Years back a friend had access to a private lake that held monster size bluegills. Due to heavy weed cover there were no skiers or jet...
Aug 20, 2025
H
highpowerdad
reacted to
Scott Danforth's post
in the thread
Steering at low speeds - Volvo Penta
with
Like
both volvo and mercruiser used the GM truck pump with a unique to volvo or unique to mercruiser reservoir. lower pressures are for ford...
Aug 20, 2025
Aug 20, 2025
H
highpowerdad
thanks for the quick reply, and it is a 1200 psi one that is needed, for the Volvo system correct, I see lower pressures available.
Aug 20, 2025
rebuild kits are only $15 (they were $8 just 4 years ago)
Aug 20, 2025
A
airshot
Nobody fishing?
Aug 20, 2025
google saginaw power steering pump replacment if you get a new kit, you get the new pump and o-ring, ready to drop into your reservoir...
Aug 20, 2025
H
highpowerdad
Any chance you (or anyone) have a GM/Delco part number, it is very confusing just googling it. Also, I guess I would need a seal kit...
Aug 20, 2025
