ingham01952
replied to the thread
Port motor out!
Update on my Volvo Penta 5.0 GXi-E issue (2004 Four Winns Vista 288): After checking all the fuses and relays, I moved on to a fuel...
Aug 20, 2025
H
highpowerdad
Volvo Penta SX-M Mysterious Rattle. Not U-Joints. Not Gimbal.
Your description sounds like the "rattle" of the internals that I get with my SX-M. I chased it for a while with some post on this...
Aug 20, 2025
A
airshot
boat snap on covers
Look around and see if you gave some old car collecters and reconstruction clubs in tour area. Often these guys do there own upholstery...
Aug 20, 2025
A
airshot
reacted to
Jimwhall's post
in the thread
boat snap on covers
with
Like
Thanks everyone. As to the use, I'll admit it's 1/3 vanity 2/3 usefulness. The boat spends the summers in my garage and the winters...
Aug 20, 2025
H
highpowerdad
Steering at low speeds - Volvo Penta
Any experience with one of these? https://www.hardin-marine.com/p-11491-high-speed-saginaw-style-power-steering-pump.aspx
Aug 20, 2025
2
2004 searay
reacted to
Scott Danforth's post
in the thread
sx-a driveshaft bellows full of oil but no leak detected under pressure and vacuum test
with
Like
Then the only thing I can suggest, fill it, run it, check it often. look again when you pull the drive for winter maintenance.
Aug 20, 2025
T
tphoyt
reacted to
redneck joe's post
in the thread
Random
with
Like
This is about the age this became my job https://www.facebook.com/share/r/19iB98CaqW/
Aug 20, 2025
J
Jeff J
SX-A thread repair
It looks like the helicoil and pan head screw with a gasket from a big Suzuki will be a good fix. I do not have a way to properly...
Aug 20, 2025
C
clearbluewater
Sqeeking sound from belt after impeller inspection
Thank you all for the feedback and suggestions. Changing the belt fixed the squeeking sound.
Aug 20, 2025
C
clearbluewater
Starting boat after 4 years - pre start steps
That's exactly what it was, the bowl gasket. I swapped it out. No leak after swap.
Aug 20, 2025
J
Jeff J
LOWER END OIL CHANGE
I use the hand impact to loosen stuff all the time. I may have to try it for tightening but beating steel threads into something with...
Aug 20, 2025
Bt Doctur
Lower unit oil leak through weep hole after impeller replacement
remove the keyway and base plate and pressure test the lower again
Aug 20, 2025
W
wyerock
Mercruiser 4.3 TKS - No Ignition Power
Appreciate the help. I started to see what all I could get to on the wiring harness, and I found a 15A fuse tucked back there. It sits...
Aug 20, 2025
R
runninfarmer
Inside of pump housing:
Aug 20, 2025
C
Crosbyman
1995 Evinrude E90TLEO charging
infinity is what your meter displays when probes do not touch..... anything else is resistance of varying values. some meter autorange...
Aug 20, 2025
