T
Terrapin
replied to the thread
Fuel Line USCG Type for Under RIB Floor
OK thanks, I will go with the A1 since I don't know whether I would comply with fuel discharge section (b) (2) (ii) of 183.558. Any...
Aug 21, 2025
Mercruiser 409 engine severe vibration issue
something is most likely wrong with the base engine level. did they use the old flywheel vs the flywheel on the 409? as AD asked, what...
Aug 21, 2025
How would a compromised bellows sink the boat?
the exhaust bellows will not sink your boat, however the u-joint bellows can given time, or a bad y-pipe to transom shield seal. water...
Aug 21, 2025
if only there were regulations on that...... wait there are...
Aug 21, 2025
K
kd4pbs
B1 is only for spaces that aren't enclosed where as A1 is rated for enclosed spaces. Why not just get the hose that you can use...
Aug 21, 2025
K
kd4pbs
posted the thread
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
Could some of you smart people help me out here? Something dawned on me while reassembling this DP-SM I've been working on all summer in...
Aug 21, 2025
A
AussieB
reacted to
MNhunter1's post
in the thread
Is it only a matter of time for leaks?
with
Like
V5's are hard to come by as it is. You may be waiting for a while to find a good deal on a 22ft OB. I'd love a big 22ft'r, but my 18ft...
Aug 21, 2025
M
MikeSchinlaub
Random
Grabbed this from S10 forum.
Aug 21, 2025
T
Terrapin
posted the thread
in
Inflatables and RIBs
I am moving my fuel tank to the bow locker on my Highfield Classic 290 Hypalon RIB. Is USCG Type B1-15 hose acceptable for the entire...
Aug 21, 2025
Did you swap a 409 for a 409, or another motor to a 409?
Aug 21, 2025
reacted to
kd4pbs's post
in the thread
LOWER END OIL CHANGE
with
Like
I just use my German torque wrench set to "Gootentight".
Aug 21, 2025
V
Voyager NY
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
I recently purchased a Certified Pre Owned (CPO)engine from Doug Russel Marine. The engine was installed and at first start up i noticed...
Aug 21, 2025
Scott06
Lower unit oil leak through weep hole after impeller replacement
Would guess its either the seal below the water pump or the driveshaft seal in upper based on leaking down the shaft below the splines...
Aug 21, 2025
K
kd4pbs
anc switch.
The best use for the ACC switch is to wire it to the automatic extending stripper pole. At least that's what I have been told... Anyway...
Aug 21, 2025
P
pae0332
posted the thread
2001 200hp HPDI wont run, rebuilt pump, changed all filters, I'm stuck
in
Yamaha & Suzuki Outboards
ok, here goes: sorry abut the long post but: i have an HPDI engine that is kicking my ass and need some outside help with it. its a...
Aug 21, 2025
