rickasbury
replied to the thread
Hot water heater
Im going to be back at the boat and will tedt it again. There was only a colld line going to that faucet- but will check the other ones...
Aug 21, 2025
T
tr@v1s
posted the thread
Mercruiser 3.0 won't "lock in"
in
Mercury MerCruiser Sterndrives & Engines
Hey all. Haven't been doing anything with boating for about 12 years. I used to be on iboats forum back then and messed around with...
Aug 21, 2025
redneck joe
reacted to
MikeSchinlaub's post
in the thread
Random
with
Like
Grabbed this from S10 forum.
Aug 21, 2025
FLATHEAD
reacted to
tphoyt's post
in the thread
Trail camera issues fixed, now pics from them ...
with
Like
I love those bear pics. My problem is I can’t decide which of the 13 birds to pick for dinner.
Aug 21, 2025
tpenfield
How would a compromised bellows sink the boat?
Yea, I did not always put those o-rings on the drive shaft, figuring that they won't really do much if the bellows gets compromised. An...
Aug 21, 2025
Mercruiser 409 engine severe vibration issue
Ayuh,...... is this an over-bored 400 SBC, or an over-bored 396 BBC,..?? I haven't heard the term 409 since the beachboys did that...
Aug 21, 2025
A
airshot
reacted to
Jeff J's post
in the thread
LOWER END OIL CHANGE
with
Like
I just did that with a slotted pan head screw on a Volvo Penta. Threads were stripped and the helicoil took out the sealing surface for...
Aug 21, 2025
aspeck
reacted to
in the thread
Random
with
Like
Aug 21, 2025
A
airshot
reacted to
kd4pbs's post
in the thread
anc switch.
with
Like
The best use for the ACC switch is to wire it to the automatic extending stripper pole. At least that's what I have been told... Anyway...
Aug 21, 2025
Ayuh,.... That seal is just to keep purged grease from the gimbel bearing from splattering all over the bilge,..... It a rather...
Aug 21, 2025
K
kd4pbs
Thanks, Scott. I'm not referring to exhaust bellows and exhaust pipe seals here, nor corrosion related issues. Those are easy for even...
Aug 21, 2025
T
tphoyt
reacted to
in the thread
Random
with
Like
Aug 21, 2025
Bt Doctur
https://www.onallcylinders.com/2020/08/21/ask-away-with-jeff-smith-out-of-balance/
Aug 21, 2025
Scott06
Prop change on my bowrider
I wouldnt touch the edge - what you describe is typical Would expect that to drop your wot rpm a tad
Aug 21, 2025
guy48065
I'll try this Solas 14x21 Even if it changes nothing it sure is purdy. I have a question about the workmanship. Everything looks...
Aug 21, 2025
