reacted to
kenny nunez's post
in the thread
How would a compromised bellows sink the boat?
with
Like
The 2 “O “ rings on the driveshaft are there to grip the gimbal bearing. There is usually a 1/4” breather hole at the 12 o clock...
Aug 21, 2025
T
tr@v1s
replied to the thread
Mercruiser 3.0 won't "lock in"
Thanks kenny. I can't seem to find it. Do you happen to have the link?
Aug 21, 2025
guy48065
posted the thread
A couple more I/O questions...
in
Boat Topics and Questions (not engine topics)
My 2000 4.3L has a standard carburetor (not tks like I first thought), distributor cap & coil. There's also a black box I'm wondering if...
Aug 21, 2025
S
svonadym
Schematic Diagram for Vintage Faria Tachometer
Thank you for your offer. See below. It sure looks like a resistor to me, but appreciate your input.
Aug 21, 2025
K
kenny nunez
Alignment adjustment, witness marks
If you have a small bottle jack or an overhead hoist loosen the mounts and either under the harmonic balancer with the jack or with the...
Aug 21, 2025
K
kd4pbs
No breather hole on this DP-SM transom shield. I was quite intimate and up-close with it for a few weeks sandblasting, Alodizing...
Aug 21, 2025
K
kenny nunez
Aug 21, 2025
K
kd4pbs
Thanks, Bondo... The one on this DP-SM is just as tight as the front crank seal or any other kind of lip seal I've ever used. That...
Aug 21, 2025
reacted to
Scott06's post
in the thread
Mercruiser 409 engine severe vibration issue
with
Like
https://powerboat.world/news/254900/Quicksilver-introduces-409-MPI-Bravo-engine Cant tell if it is a chevy based or not valve covers...
Aug 21, 2025
B
boscoe99
2001 200hp HPDI wont run, rebuilt pump, changed all filters, I'm stuck
Did the pump rebuilder pressure test the pump? If the pump is not outputting rated pressure while it is being supplied with the gasoline...
Aug 21, 2025
Bob Weily
Force 40 issues
clutch dog*
Aug 21, 2025
K
kenny nunez
There is a tutorial on this site on how to adjust the shift cable.
Aug 21, 2025
K
kenny nunez
It has to be a flywheel problem. And maybe the wrong harmonic balancer.
Aug 21, 2025
FLATHEAD
reacted to
WIMUSKY's post
in the thread
Trail camera issues fixed, now pics from them ...
with
Like
😂 Looking for that horny boy.....🦌
Aug 21, 2025
Scott06
Aug 21, 2025
