GOOD NEWS. . . . The PICTURE UPLOAD FUNCTION IS WORKING !!! The tech folks at the parent company have been able to remedy the issue. You can upload pictures once again. Thank you for your patience.
Bob Weily
replied to the thread
Force 40 issues
How do you usually do that? I took it to a machine shop
Friday at 7:30 AM
Bob Weily
reacted to
jerryjerry05's post
in the thread
Force 40 issues
with
Like
That's fixable. Just square off the edges.
Friday at 7:27 AM
J
JPsanta
Gas guage
interesting , went and checked fuel gauge yesterday at supper time , gauge said tank was full , before when i start this post , i had...
Friday at 7:26 AM
JustJason
If you're wondering if your anti siphon valve is stuck, or clogged, here's a test....
https://forums.iboats.com/threads/how-to-testing-your-boats-fuel-system.278553/ I wrote that back in 2008. That will tell you how to...
Friday at 7:16 AM
C
1998 Johnson J115ELECM idle adjustment help!
My Johnnyrude Service manual covers your motor. The initial idle mixture setting is spec'd at 5-3/4 turns open. Make sure the motor...
Friday at 7:14 AM
M
MBAKER
wheel bearing seals
If you go online to places like thebigbearingstore.com if you buy in bulk like 5 or 10 minimum. these things are only a buck and some...
Friday at 7:13 AM
JustJason
2005 4.3 liter Mercruiser ignition trouble
Get a 12-14 gauge jumper wire with alligator clips and clip one end to the same terminal on the key switch, the other end to the...
Friday at 7:09 AM
C
cowl air inlet on mercury 9.9.
Exhaust leaks are often caused by the powerhead base gasket.
Friday at 7:08 AM
C
cyclops222
Well I am feeling great with my medical cup of Caffeine. So I will go to the boat and see if there is a removable part in the cowl /...
Friday at 6:53 AM
T
tphoyt
Caffeine good for sleepy old guy ?
I love my morning coffee. I can function without it but it sure makes my day better. I usually have a cup or two after dinner as well...
Friday at 6:49 AM
C
cyclops222
Scary
81 and blue sky. (y)(y)
Friday at 6:40 AM
C
cyclops222
I am buying a 1/2 of a quart of Half and Half milk to enjoy each cup and increase my Calcium intake. Thank you everyone. :):) L I G again.
Friday at 6:35 AM
C
cyclops222
reacted to
dingbat's post
in the thread
with
Like
I typically drink 2-3 cups of black coffee before leaving the house in the morning. Drink two more cups during my morning meeting with...
Friday at 6:29 AM
C
crazy charlie
options for boat cover supports
As your pic shows, your cover either does not fit correctly or you do not have it strapped tight enough.Inflatable is a good idea .You...
Friday at 6:19 AM
Purple on I
Friday at 5:49 AM
