GOOD NEWS. . . . The PICTURE UPLOAD FUNCTION IS WORKING !!! The tech folks at the parent company have been able to remedy the issue. You can upload pictures once again. Thank you for your patience.
Scott06
replied to the thread
Best rust loosening material
Kroil
Friday at 9:08 AM
2005 4.3 liter Mercruiser ignition trouble
Correctly I don't see how the kill switch is the problem because you said The purple is not getting power so it's currently not the...
Friday at 9:01 AM
K
kepruno
Not my boat but it looks very similar to this. Mine has a pad behind it that I guess is for your arm.
Friday at 8:54 AM
K
kepruno
I bet you are right but I don’t think that will tell me where the problem is. I now know I’m losing power somewhere between the switch...
Friday at 8:50 AM
K
KTEC
1998 Johnson J115ELECM idle adjustment help!
Is a timing light the only way to confirm the QuickStart system disconnects? My understanding is this system advances timing by about 10...
Friday at 8:24 AM
K
KTEC
reacted to
Chris1956's post
in the thread
with
Like
My Johnnyrude Service manual covers your motor. The initial idle mixture setting is spec'd at 5-3/4 turns open. Make sure the motor...
Friday at 8:23 AM
C
cyclops222
Marine Sea Foam
Are we serious ? Difference in HP to go to 80 mph from 60 mph in a 21' old boat ? Post this question in a real Bass Boaters forum to...
Friday at 8:21 AM
D
DeepCMark58A
Caffeine good for sleepy old guy ?
I can't drink coffee, I did for years but now my gut does not toloratre it. Do not try an energy drink that is poison.
Friday at 8:18 AM
K
kenny nunez
Mercruiser 3.0 won't "lock in"
If the splines completely went away there has to be a alignment problem. sierra #18-2321 looks like the coupler that you need Mercruiser...
Friday at 8:15 AM
C
cyclops222
reacted to
redneck joe's post
in the thread
Marine Sea Foam
with
Like
There will be many that say seafoam is a waste of money, I'm a believer however. For 8 bucks why not try? Last time I used it was on...
Friday at 8:09 AM
K
kd4pbs
If you're wondering if your anti siphon valve is stuck, or clogged, here's a test....
And sometimes, you just gotta go with your gut. Had a Chap Signature that unfortunately had a Yamaha I/O. Not that this is related to...
Friday at 7:57 AM
JoeMan
posted the thread
Prop suggestion for 1995 60 hp Merc 2 cycle
in
Mercury & Mariner Outboards
I'm NOT looking to win a race here....but I'd like a recommendation for a prop that will help me get out of the hole nicely, and then...
Friday at 7:54 AM
Texasmark
2004 Mercury 115 2 stroke - oil injection block off plate
1. I don't know what gold means...having had both of those (90 and 115) mine showed no signs of any gold. 2. As I got older I boated...
Friday at 7:48 AM
T
tr@v1s
reacted to
kd4pbs's post
in the thread
with
Like
I see them on eBay and Amazon. I imagine every marine supplier worth their weight sells them. Call a supplier with your engine info...
Friday at 7:47 AM
K
kd4pbs
Friday at 7:45 AM
