W
Willyclay
reacted to
Pvaughan23's post
in the thread
Starting a 1974 Tri-Hull Restoration, it's a Stryker Mark IV model. Need help with any information or an owners manual.
with
Like
It's registered and insured, and I'm licensed so after this weekend I'll have the batteries to test the outboard then I'll get some fall...
Sunday at 9:09 PM
L
lgaytan
posted the thread
1978 50hp Mercury timing and synchronization
in
Mercury & Mariner Outboards
Hello does anyone knows what this screw is for? I don't see it in the service manual that I have, the issue with this screw is that when...
Sunday at 8:41 PM
flyingscott
replied to the thread
1988 Johnson 70hp - VRO or not to VRO?
Maybe from the old non synthetic oils. Synthetic oils generally have much better flow rates. That being said snowmobiles seem to do okay?
Sunday at 8:35 PM
T
tphoyt
reacted to
Scott06's post
in the thread
projects other than boats
with
Like
Nice attched is my 65 GTO, second photo is the nee to me engine just had built for it. Hopefully going in the car over the next couple...
Sunday at 8:02 PM
M
mayjamest
posted the thread
Time For A New Fuel Pump?
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
I was getting really bad pump whine the other day. Pulled the regulator out, cleaned off the gunk and it seemed to fix the problem for...
Sunday at 7:53 PM
ESGWheel
Low Voltage at RPM?
Thanks for the extensive background. But only is causing me to ask more questions :) I am surprised at the need to move the fuel tank...
Sunday at 7:43 PM
ESGWheel
reacted to
PutMeOnTheWater's post
in the thread
Water pump leak?
with
Like
Will do! Only got a week or 2 of season left in KC and the other pump won’t arrive for a week or 2 so gonna give it a go and see what...
Sunday at 7:25 PM
P
PutMeOnTheWater
Water pump leak?
Sunday at 7:15 PM
Scott06
Sunday at 7:13 PM
ESGWheel
Water pump leak?
Unsure of the impact of regular grease on the rubber of the impeller. However, you can use some kitchen dish detergent to lube it up...
Sunday at 7:13 PM
P
PutMeOnTheWater
Water pump leak?
Question on this, if I didn’t have any impeller grease. Would regular marine grease work? I have an oem impeller that I can put in this...
Sunday at 6:14 PM
P
PutMeOnTheWater
Water pump leak?
Just to add some confirmation to that and maybe save someone else the time of trying to save a few bucks on Amazon here’s a picture of...
Sunday at 6:13 PM
C
cyclops222
reacted to
alldodge's post
in the thread
Where are the shutoff valves?
with
Like
Not going to find much of anything on the water system of a boat. Most don't have any valves from factory, any that are found have been...
Sunday at 5:52 PM
C
cyclops222
Low Voltage at RPM?
Should be the SLIP RINGS on a alternator / generator.
Sunday at 5:49 PM
C
cyclops222
reacted to
Open Water's post
in the thread
with
Like
2.6 oz of oil per gallon of gas. Peace of mind.
Sunday at 5:47 PM
