matt167
replied to the thread
1979 Starcraft American Offshore 22’
For every tin boat StarCraft made, they basically had an identical fiberglass model available beside it
Yesterday at 6:47 PM
P
Pmt133
cooking
Made some baguettes.
Yesterday at 6:31 PM
A
airshot
Solar charging batteries
Under warranty ?
Yesterday at 6:26 PM
F
FishAtFive
87 50HP VRO Evinrude - Could this be my problem?
For now I have just replugged it with a fresh hose. If it fixes the issue I will get the plug (321164 - Manifold Plug). So it sounds...
Yesterday at 6:25 PM
BWR1953
reacted to
redneck joe's post
in the thread
I was just four months old
with
Like
OK this was about star trek
Yesterday at 6:22 PM
L
lgaytan
How can I make my Tracker 40 HP faster?
About the trim position, make trials in different possitions, I always used the same position in my boat and got 25- 26 MPH out of my 50...
Yesterday at 6:10 PM
matt167
Seafoam vs. Marine Pro Seafoam
It works okay as a decarbonizer, which isn’t what it was designed for. Water itself can work okay as a decarbonizer though
Yesterday at 6:04 PM
ESGWheel
1981 MerCruiser 120 tick/ squeak
I think same as before. And since getting worse my thoughts are to stop running it and start the investigation and teardown. But that...
Yesterday at 5:52 PM
T
tank1949
engine mounted raw water pump with alpha drive
Pully or crank pump? My boat's closed cooled MC was not run in a couple of years and the crank pump's water in its line evaporated...
Yesterday at 5:38 PM
C
cyclops222
Nobody fishing?
Yellow Perch are for eating !!!!!!!!!!!!!!!!
Yesterday at 5:34 PM
D
Dannysmyk
I was able to get a video of it running. Seems to be getting worse. What do you guys think it is? The video with the engine cover off is...
Yesterday at 5:30 PM
T
tank1949
Milk in reservoir, not in outdrive
You might be getting rain water seeping into reservoir. Also have line pressure tested from reservoir back. You will find leak.
Yesterday at 5:28 PM
C
Crosbyman
2003 Evinrude ficht stalls at medium speed
CHAT GPT OPINION.... 🧩 Common Causes (for the fuel-vs-TPS version of Code 57) Category Typical Fault TPS signal erratic or out of...
Yesterday at 5:27 PM
redneck joe
Lead acid battery. Two questions
This is the one I'm eyeballing...
Yesterday at 5:25 PM
redneck joe
OK so 50 amp on a 115 rc is 2 plus hours and I'm assuming that is at full thrust so longer in running 50%
Yesterday at 5:21 PM
