replied to the thread
My block is drained, right?
on a V-engine. the only cross-over point on the block is the water pump connections. everything below that is in their own pocket on...
Nov 20, 2025
WIMUSKY
Trail camera issues fixed, now pics from them ...
No doubt. The guy is 73, has shot(I mean harvested) a ton of deer in his lifetime. He just likes being in the woods. So if he pulls...
Nov 20, 2025
P
Paradise pontoon
posted the thread
MSX-150 wont go full throttle
in
PWC (Jetskis, Waverunners, etc.)
Have a 2004 MSX-150 jetski . Wont go full throttle. Runs fine at half throttle but thats it.Replaced System Module, PPU interface...
Nov 20, 2025
WIMUSKY
reacted to
FLATHEAD's post
in the thread
with
Like
Nov 20, 2025
G
Goofy420
Johnson Evinrude 130hp vro pump
Thank you. I think we have been through every line on the boat.
Nov 20, 2025
R
Cotter pin for Prop...Any one will do??
Mercury---" Shear proof drive "---has sold a lot of props , gears and drives.
Nov 20, 2025
C
Make sure you do not have any air leaks into the gasoline lines. If air leaks, from say, the main strainer, the VRO pump will pump more...
Nov 20, 2025
aspeck
reacted to
FLATHEAD's post
in the thread
with
Like
Nov 20, 2025
aspeck
Re-post of Boomyal's Brined Turkey Recipe!
Chips and chunks ... some times I soak them in water if I want a light smoke and other times I let 'em rip and refill the hopper.
Nov 20, 2025
Texasmark
Back in the '50's dad bought a 10 HP Scott Atwater outboard. Where the tiller handle attached to the engine proper there was a flat...
Nov 20, 2025
Lou C
1996 Four Winns Sundowner with 5.0 Cobra engine and drive
Eaton's Neck Long Island with the Connecticut coast in the far distance. I don't take the bowrider in LI Sound unless the conditions are...
Nov 20, 2025
Texasmark
reacted to
Scott Danforth's post
in the thread
18ft aluminum boat v hull
with
Like
pretty sure Jim is right on it possibly being a sea nymph. dont see a 18' in what I found.
Nov 20, 2025
D
DeepCMark58A
Exactly what it sounds like a grill or smoker that uses sticks of wood.
Nov 20, 2025
southkogs
reacted to
dwco5051's post
in the thread
Random
with
Like
Many years ago when my father was in his late 60's he dropped his rod off the boat over on Speck's home lake. The water was clear...
Nov 20, 2025
G
Goofy420
Yes, it's definitely a lack of fuel issue. Is the after market VRO ok to use. It has a 5yr warranty
Nov 20, 2025
