R
replied to the thread
Cotter pin for Prop...Any one will do??
Only use a stainless pin.
Nov 20, 2025
A
airshot
reacted to
Texasmark's post
in the thread
with
Like
Back in the '50's dad bought a 10 HP Scott Atwater outboard. Where the tiller handle attached to the engine proper there was a flat...
Nov 20, 2025
A
airshot
If you follow recommended maintainence schedules, SS pins are not needed for fresh water. Most all motor mfgrs highly recommend pulling...
Nov 20, 2025
WIMUSKY
Trail camera issues fixed, now pics from them ...
Absolutely! Everyone has different reasons for hunting. I completely get putting food on the table. I also understand that priorities...
Nov 20, 2025
A
airshot
reacted to
tphoyt's post
in the thread
with
Like
Grabs few while you’re at it so you have them next time. I keep extras along with extra nuts and thrust washers attached to my spare...
Nov 20, 2025
C
Comogene
Hot water heater
If you do not have a check valve in the cold water feed to the heater, and it appears that you do not, I suggest that you install one...
Nov 20, 2025
WIMUSKY
reacted to
aspeck's post
in the thread
with
Like
I am a little younger than him and haven't hunted overseas, but had an offer to hunt a guys farm in South Africa. And I work full time...
Nov 20, 2025
aspeck
Nov 20, 2025
Lou C
My block is drained, right?
What I’ve done is open the block drains first, before removing that big hose at the bottom of the water pump, because that shows you if...
Nov 20, 2025
Lou C
reacted to
Scott Danforth's post
in the thread
with
Like
on a V-engine. the only cross-over point on the block is the water pump connections. everything below that is in their own pocket on...
Nov 20, 2025
B
Bottom Mapping
Aluminum Boat Paint
We had a dealer Rhino- line a 1972 Smoker Craft that had never been painted. The shop went into a song and dance about custom work and...
Nov 20, 2025
Replacement Trim Hydraulic Pump for OMC Sterndrive
You can use the Volvo pump. Look for the part number using the "MD" as the model number which is the Volvo equivalent of your drive...
Nov 20, 2025
reacted to
in the thread
with
Like
Nov 20, 2025
dwco5051
reacted to
Texasmark's post
in the thread
with
Like
Nov 20, 2025
S
saltchuckmatt
Johnson Evinrude 130hp vro pump
To answer your question directly, no do not use aftermarket stuff. Rebuild it...fuel diaphragm only most likely... But do the other...
Nov 20, 2025
