redneck joe
replied to the thread
Random
Nov 23, 2025
tpenfield
I/O (Sterndrive) Conversion to Outboards
The 2 tables (5&6) list under water properties. Keep in mind that the bolts do not (should not) get wet, other than some periodic dampness.
Nov 23, 2025
dingbat
Boat is put away for winter. What to do every day ?
The bigger fish are starting to show up in better numbers. The bulk are off Jersey Unfortunately, pulling the boat may sooner than...
Nov 23, 2025
dingbat
daily music fix
Lost a close, childhood friend at 19 to suicide. Back to back family tragedies and the family dynamics afterward set the stage. He was...
Nov 23, 2025
D
DeepCMark58A
Pulled the boat lift yesterday. I had to cut down a red cedar so the canopy would clear, used a come a long to pull the lift a steep 8'...
Nov 23, 2025
Scott06
Recommended parts
Before you get too far into it ($$$) drill your transom and stringers. Check the gimbal bearing for smoothness , if rough replace. Look...
Nov 23, 2025
dingbat
May want to look at tables 5 and 6 in the attachedm...
Nov 23, 2025
M
MikeSchinlaub
Redoing a Starcraft Islander transom using Coosa board.
Ok, you kept mentioning fiberglass so that's what I thought. Everything else still applies though. Coosa is like a stiff foam board...
Nov 23, 2025
flashback
I suspect once installed the bolts will never be removed similar to the hylocks used in aircraft of old. The head of the nut broke off...
Nov 23, 2025
T
tphoyt
I will have to look into that as well. I use a lot of stainless for the marine environment on a seasonal basis and even though I know...
Nov 23, 2025
E
ejnichol
reacted to
Scott Danforth's post
in the thread
Fuel starvation conundrum
with
Like
Fuel lasts a maximum of 12 months. Pull the fuel and run fresh in spring
Nov 23, 2025
I personally wouldn't worry about it in an aluminum boat
Nov 23, 2025
aspeck
reacted to
WIMUSKY's post
in the thread
Trail camera issues fixed, now pics from them ...
with
Like
Not at all. Even tho I quoted you it was really meant for the masses. He's not a typical trophy hunter. He just likes being in the...
Nov 23, 2025
Ted, look for 316-condition B hardware It's a much harder 316 variant that is less likely to gall
Nov 23, 2025
redneck joe
daily music fix
If you are a fan of the current iteration of Robert Plant and have 30 minutes to spare...
Nov 23, 2025
