R
R Lowery
reacted to
Scott Danforth's post
in the thread
Recommended parts
with
Like
I agree test drilling the transom and stringers with the motor out 5/16" drill, mark off a drill depth of 1/2" to 3/4" Drill 2" above...
Nov 23, 2025
R
R Lowery
replied to the thread
Recommended parts
reguardless of what i find rot wise ill be keeping the boat and repairing it, it has a nice aluminum hull and is about the perfect size.
Nov 23, 2025
R
R Lowery
Recommended parts
Thanks, ill check those, and is quicksilver same as oem? when i tear into it i will be replacing stringers and modifying the floor. i...
Nov 23, 2025
Recommended parts
Nov 23, 2025
Lou C
OMC 4.3 V6 dry joint "batwing" conversion exhaust kit
Here's a few tips, because the clearances on the starboard side are tight, put a little silicone grease inside the rubber hoses...
Nov 23, 2025
redneck joe
2025 NFL/CFB News and Nonsense
https://sports.yahoo.com/college-football/breaking-news/article/notre-dame-builds-21-0-lead-on-syracuse-before-offense-takes-the-field-in...
Nov 23, 2025
T
tphoyt
reacted to
redneck joe's post
in the thread
Random
with
Like
Nov 23, 2025
Scott06
Winterization difficulty
Its much easier with drive off. Taking the drive off seems like a big deal until you have done it. You need an alignment bar to algin...
Nov 23, 2025
P
Pmt133
Boat is put away for winter. What to do every day ?
Been particularly crappy lately hasn't it? Then again last fall may have spoiled me....
Nov 23, 2025
P
Pmt133
reacted to
dingbat's post
in the thread
with
Like
The bigger fish are starting to show up in better numbers. The bulk are off Jersey Unfortunately, pulling the boat may sooner than...
Nov 23, 2025
P
Pmt133
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
According to AI . . . "Coarse thread is more subject to loosening under vibration, while fine thread is less likely to loosen. This is...
Nov 23, 2025
MSX-150 wont go full throttle
From my searching, it's probably best to ask your question on the Green Hulk forum. Your ski is a complicated one with a turbo. Finding...
Nov 23, 2025
reacted to
Scott06's post
in the thread
Recommended parts
with
Like
Before you get too far into it ($$$) drill your transom and stringers. Check the gimbal bearing for smoothness , if rough replace. Look...
Nov 23, 2025
C
ccourser
Thanks for the input I prepped the block ordered some parts and will let you know how it goes.
Nov 23, 2025
rolmops
Redoing a Starcraft Islander transom using Coosa board.
Thank you for your answer, you certainly gave me food for thought. My Starcraft Islander is aluminum. A 1.5 inch 4by8 26 grade is $582...
Nov 23, 2025
