R
replied to the thread
90 Mercury 40HP motor
Remove lower bypass cover and inspect pistons / rings.
Tuesday at 8:43 AM
FLATHEAD
2025/'26 CFB Playoffs
It was an entertaining game. Mendoza will have a major pocket full of money. As far as the officiating, they definitely let the kids...
Tuesday at 8:36 AM
D
DeepCMark58A
transom mount trolling motor
You can buy a trolling motor that mounts to your outboard.
Tuesday at 8:00 AM
What’s the Best Way to Transport a Boat Safely?
Ayuh, 'n How Big is this boat,..??..??..??
Tuesday at 7:36 AM
outdrive knocking noise while cruising.
Ayuh,..... Welcome Aboard,.... you posted this at the end of a thread in the OMC forum, I moved it to the Merc I/O forum for you,....
Tuesday at 7:34 AM
dwco5051
reacted to
airshot's post
in the thread
My safety tip of the day is...
with
Like
Another issue can be how close together the waves are. Here on Lake Erie the waves are closer together, on average about 7' apart, so...
Tuesday at 7:33 AM
C
cyclops222
reacted to
jlh3rd's post
in the thread
Less people in box stores.
with
Like
double edge sword. I lament the fact that box stores are dwindling. Yeah, I miss my Sears, seriously, I do. But crowds, waiting...
Tuesday at 7:31 AM
Texasmark
High RPMS instant rpm drop to zero and back
You didn't specify a lot of details but in addition to Alldodge's comments, you may have corrosion on some mating electrical...
Tuesday at 7:28 AM
C
That could be an indication of fuel delivery issues, if it happens regularly at a given RPM. Run it on a portable tank, with a short...
Tuesday at 7:28 AM
C
You might stick a bore scope into the bottom two cylinders and see if the cylinders are scored, or if the rings are stuck. Sometimes...
Tuesday at 7:25 AM
C
cyclops222
reacted to
Lou C's post
in the thread
1990 bayliner trophy 24 foot walkaround
with
Like
Why not just re do the splash guard that was there? Better drains?
Tuesday at 7:21 AM
C
'84 90 hp Johnson Crossflow. Water coming from engine front. Ain't lookin good.
Gee, the leak looks to be under the upper motor mounts. There are a couple of places for it to leak, or to have a crack, in that area...
Tuesday at 7:19 AM
C
cyclops222
reacted to
airshot's post
in the thread
What razor and single razor blade in it are available ? CHEAP Who sells such a simple razor and holder ?
with
Like
Unfortunately, in most cases, they are the same pump. The consumer just pays up front for the free replacements down the road. The...
Tuesday at 7:12 AM
L
Lpgc
reacted to
alldodge's post
in the thread
Mercruiser 350 MAG MPI
with
Like
Original problem was a hot start issue and now after injectors came back from testing the motor is flooding. While the hot start issue...
Tuesday at 6:53 AM
P
Pmt133
2025 - My Season By The Numbers
Our camper behind the ecoboost does about 9 mpg and thats below 60 mph. The only thing eco I've found with it is the name. :LOL: Pulling...
Tuesday at 6:40 AM
