Lou C
replied to the thread
4.3 crankshaft/housing oil leak - next steps?
I think the oil pan on the newer 4.3s is aluminum, so might not be so prone to rust, I have sprayed my tin one with...
Feb 5, 2026
craig newton
Engine dieseling
I think there's between 50 and 55 hours on the plugs. They appear to be burnt right under the letters ACDelco. Also I was told these...
Feb 5, 2026
P
Pmt133
reacted to
Bondo's post
in the thread
Engine dieseling
with
Like
Ayuh,..... I merged yer threads to keep yer info together,..... no need to start a new thread,... If yer intake manifold has 12...
Feb 5, 2026
craig newton
Engine dieseling
Thanks Bondo. My engine does have the Vortec heads.
Feb 5, 2026
M
Mc Tool
67 Year Old Head Bolts
Just me but I dont like using impact drivers on corroded stuck fasteners. There is a skill learnt of previous disasters where one can...
Feb 5, 2026
C
Crosbyman
heating the bolt allows a heat transfer to the engine's bolt threads and body in effect releasing the bind on the bolt itself . This...
Feb 5, 2026
M
Mc Tool
reacted to
LaqueRatt's post
in the thread
with
Like
Thanks for the prompt replies. I have both a 1/4" hex impact and a 1/2" pneumatic, but think maybe I'll try to work them loose by hand...
Feb 5, 2026
B
beta
1995 Crownline 202BR Restore
I have a space heater running in the garage but it can only do so much when it's 15-20deg outside. Once the overnight lows go back to...
Feb 5, 2026
S
saltchuckmatt
Any salt evidence or not ...if not sure post pictures. Your talking about the "red headed stepchild" she ate the apple, so that's a...
Feb 5, 2026
FLATHEAD
Been a little cold.
Stick around Pa a little longer, expected temps in single digits with 40 to 50 MPH wind this coming weekend in Montgomery county. Wind...
Feb 5, 2026
S
ShoalSurvivor
I was surprised at how easy it was to pull the motor. All of the connections are pretty obvious, and it only took a couple hours to...
Feb 5, 2026
S
ShoalSurvivor
reacted to
airshot's post
in the thread
with
Like
Getting the engine out and back in, is the hardest parts to do....good luck...make her ready for spring !
Feb 5, 2026
S
ShoalSurvivor
reacted to
Chris1956's post
in the thread
with
Like
Check the oil pan for rust. They can rust thru pretty easily in the salt water. Obviously, they are easier to replace when the engine...
Feb 5, 2026
redneck joe
Great loop speed record attempt
Me too
Feb 5, 2026
aspeck
reacted to
BWR1953's post
in the thread
A little Home Remodel
with
Like
Nice!(y)
Feb 5, 2026
