C
camboat
replied to the thread
Switching from Volvo TBI to Carb on a 1996 5.7 GI
Thanks Scott That’s what I was thinking. I added a 7 amp inline fuse and moved it to the ignition purple wire. I will check it out in...
Feb 5, 2026
H
halsteadmorris
reacted to
saltchuckmatt's post
in the thread
2002 Johnson 150 (Carb) Oiler Delete
with
Like
I should add, that it's much more "convenient" to use the oil bottle for that fuel consuming lady and it's very reliable. The oil...
Feb 5, 2026
flyingscott
reacted to
airshot's post
in the thread
Prince craft boats
with
Like
Based on my limited exposure the early models had some construction issues, but later models have had few complaints that I know of...
Feb 5, 2026
B
boscoe99
Yamaha F225 ECU Upgrade
The -50-00 wire harness will not work with the later ECU's. Would be very simple to wire a bright red light on the dash to indicate the...
Feb 5, 2026
T
tphoyt
Random
I wear this with pride
Feb 5, 2026
T
tphoyt
reacted to
redneck joe's post
in the thread
Random
with
Like
Feb 5, 2026
J
Jmunk
4.3 crankshaft/housing oil leak - next steps?
Yes, I know it’s plastic. My experience has been it’s fairly easy on the ones I’ve done.
Feb 5, 2026
P
Pmt133
reacted to
redneck joe's post
in the thread
2025 Splash of the Year Nominations!
with
Like
I splashed but as always with every boat ive owned never done.
Feb 5, 2026
Scott06
That’s where mercruiser takes the 12 v from the purple 1409 will also need a ground wire for choke , I just attached mine to carb body
Feb 5, 2026
redneck joe
Random
Feb 5, 2026
redneck joe
Feb 5, 2026
redneck joe
Wondering if I can add power trim to my 82 mercury
It has already been megerd to this one. Keep asking questions here an read this thread from the beginning again to make sure you have...
Feb 5, 2026
M
MyTie
@boscoe99 wrote (and rewrote) "The -51 wire harness should work with either of the aforementioned ECU's." It was clear (both times)...
Feb 5, 2026
C
camboat
I have another question I wired the purple/white wire to the top left post per wiring diagram. Checking voltage. This post only puts out...
Feb 5, 2026
S
ShoalSurvivor
reacted to
Lou C's post
in the thread
with
Like
I think the oil pan on the newer 4.3s is aluminum, so might not be so prone to rust, I have sprayed my tin one with...
Feb 5, 2026
