M
MikeSchinlaub
reacted to
SlipperyOar's post
in the thread
1981 Springbok 18' Restoration/Renovation
with
Like
Outside view of the starboard console progress. Like I had said before I’m going to use a nice piece of wood as the console dashboards...
Feb 9, 2026
Bugzilla46310
reacted to
redneck joe's post
in the thread
1994 Starcraft Super Fisherman 170 Rebuild Help
with
Like
Kinda like dating (buying the boat), it's the chase...
Feb 9, 2026
N
Nordin
replied to the thread
Wiring a 3 wire trim/tilt pump to throttle handle switch
As Scott says, you need to operate the T&T with to relays and control them from the switch in the remote control handle.
Feb 9, 2026
N
Nordin
reacted to
Scott Danforth's post
in the thread
with
Like
the switch in the handle is operating the contactors which operate the motor. no way to run motor wiring thru a switch small enough to...
Feb 9, 2026
redneck joe
Random
Been there, done that, do not want another tshirt...
Feb 9, 2026
Feb 9, 2026
New Stuff on Vehicles likes/dislikes
my issue isnt having to replace the idler, its having it go bad with only 24000 miles (under 39,000 kilometers). so if that bit of...
Feb 9, 2026
Fun Times
Alpha One Gen II - bell housing bushing/seals - updated design?
Being your serail number is 0L517680 which is above 0F094775 you still have ordered an updated design kit that will work just fine as...
Feb 9, 2026
Superjetjim
Mercury V6 XR2 - Does this Stator looks bad?
UPDATE - so managed to water test it again yesterday. Still wont pick up in the water, it bogs. Took this video as we sprayed starter...
Feb 9, 2026
Superjetjim
reacted to
racerone's post
in the thread
with
Like
Essentially it is revving because there is NO load on the prop !
Feb 9, 2026
I typically change idlers at 60K miles on all my cars. Was on a trip in Big Bend Texas during Covid and there was a Subaru sitting in...
Feb 9, 2026
R
99 3.1l ox66 wont rev (what am i not thinking of here)
???----In reverse there would be lots of exhaust in the water and thus less load !
Feb 9, 2026
R
rjcamel2355
Less load in reverse than in forward was not something I thought of or considered. Just assumed since the prop was submerged and loaded...
Feb 8, 2026
9
99yam40
reverse does not load it up as much as forward is my only thought on that. and a lot can happen in 2 years on the injectors
Feb 8, 2026
R
rjcamel2355
No sir, I haven't. Im leaning towards a timing/spark issue though. I haven't disconnected the O2, to see if it would rev up (I know...
Feb 8, 2026
