T
tphoyt
reacted to
DeepCMark58A's post
in the thread
Nobody fishing?
with
Like
Nephew and his buddy are coming up this weekend, we are going to be more mobil this time and see if we can find some active pike during...
Feb 10, 2026
9
99yam40
replied to the thread
99 3.1l ox66 wont rev (what am i not thinking of here)
Yep, think it was the Z motors that dropped cylinders at idle and dropped more if you revved it while in neutral
Feb 10, 2026
D
DeepCMark58A
Nobody fishing?
Feb 10, 2026
M
mav6759
posted the thread
2004 Nitro 640XL Fuse Box Location and Mounting.
in
Electrical, Electronics, Audio and Trolling Motors
I had a quick question for all my Nitro owners and their fuse box location. I'm assuming the fuse box is located under the dash. Here is...
Feb 10, 2026
M
mav6759
posted the thread
2001 Mercury 90hp Outboard Hard Start
in
Mercury & Mariner Outboards
I have a 2001 Mercury 90hp with a hard start. At first start up the motor runs great no issues and idles fine. Now i do have to slam it...
Feb 10, 2026
B
bnorth1
1994 Starcraft Super Fisherman 170 Rebuild Help
I can definitely strap them up. Great idea!
Feb 10, 2026
R
Starts right up sometimes, but other times crank no start
Do you hold the key pressed in while cranking it over ?--Have you tested operation of the electric primer valve ?-----The bulb is a...
Feb 10, 2026
M
MikeSchinlaub
You definitely need some way to hold the lids when the last screws come out. They can get pretty heavy, and trying to hold the lid in...
Feb 10, 2026
Needs some volts and amps for your 24 trolling kicker ?
Don't see how that is going to work very well Specs list 20Amps max and with 15Amps add cooling fan which will draw power 【Output...
Feb 10, 2026
B
bnorth1
Totally makes sense, I don't have a helper, so it's always all me! haha. But solid advice.
Feb 10, 2026
reacted to
Scott Danforth's post
in the thread
Boat value
with
Like
two things get repeated often on this site: if you want to make a small fortune restoring boats, start with a large one... restore the...
Feb 10, 2026
2000’s Bayliner 175 I/O
replace all the plastic thru-hulls if you get it, they will fail soon.
Feb 10, 2026
Boat value
Feb 10, 2026
P
Pmt133
posted the thread
Thinking about making a trailer cover... Opinions wanted.
in
Boat Restoration, Building, and Hull Repair
So it's not a matter of knowing that I can do it... I can. I think it's more if it's worth the resources and time. The goal: Build a...
Feb 10, 2026
L
Lpgc
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
The hump speed/angle is the highest angle of incline the boat reaches while coming up on plane. In terms of degrees of incline, it is...
Feb 10, 2026
