matt167
replied to the thread
2000’s Bayliner 175 I/O
Have actually 2 since all I really like is StarCraft. Problem is big boat still needs a laundry list including paint, wiring , some...
Feb 10, 2026
M
Mc Tool
Needs some volts and amps for your 24 trolling kicker ?
😁Far out , should be able to ski behind that 😆
Feb 10, 2026
M
Mc Tool
15-20a? I got a small watersnake and that draws 45a max . What happens if you give it a bit much wellie ? , fry the unit and leave you...
Feb 10, 2026
dingbat
reacted to
DeepCMark58A's post
in the thread
Nobody fishing?
with
Like
Nephew and his buddy are coming up this weekend, we are going to be more mobil this time and see if we can find some active pike during...
Feb 10, 2026
dingbat
Trolling motor spec: PWM Frequency: To avoid audible humming noises, it is recommended that PWM controllers operate around 15–25 kHz...
Feb 10, 2026
A
airshot
When it sounds to good to be true....it is !
Feb 10, 2026
A
airshot
Mercury Tempest, Turning Point Mach 3 or Michigan Wheel Apollo?
If my memory serves me correctly, the rake is what controls bow lift, but you need someone with more prop expertise than I have.
Feb 10, 2026
A
airshot
reacted to
jlh3rd's post
in the thread
with
Like
I prop for the higher end of the manufacturer's recommended max rpm @WOT for the longevity of my engine. Everything else becomes what...
Feb 10, 2026
A
airshot
I would look at a good aluminum hull, and forget the cheap glass hulls.
Feb 10, 2026
S
saltchuckmatt
reacted to
JeepGuy319's post
in the thread
Starts right up sometimes, but other times crank no start
with
Like
Hi everyone, I am new to boats and 2 stroke motors, but I do have mechanical experience working on cars and small engines. Anyway, I...
Feb 10, 2026
S
saltchuckmatt
reacted to
racerone's post
in the thread
with
Like
Do you hold the key pressed in while cranking it over ?--Have you tested operation of the electric primer valve ?-----The bulb is a...
Feb 10, 2026
matt167
If I end up getting one I’ll be sure to.
Feb 10, 2026
S
saltchuckmatt
This should be an interesting debate.
Feb 10, 2026
S
saltchuckmatt
reacted to
Crosbyman's post
in the thread
with
Like
this little $20 module should supply a 24v from your 12v battery if you mostly slow troll. it can give you 15- 20 amps and no...
Feb 10, 2026
S
saltchuckmatt
reacted to
Chris1956's post
in the thread
2002 Johnson 150 (Carb) Oiler Delete
with
Like
Gee, the standard oil reservoir in that motor is good for at least 75 gallons of fuel. I fill the oil reservoir each time I fill the...
Feb 10, 2026
