flashback
replied to the thread
I/O (Sterndrive) Conversion to Outboards
Getting pretty heavy eh..:)
Feb 11, 2026
Cuppy420
Triton 175 rear deck removal
I got it out!! I found a screw on either side hidden by carpet! I used a magnet and it found them! Thanks everyone for your help!
Feb 11, 2026
S
SlipperyOar
1981 Springbok 18' Restoration/Renovation
Both consoles almost fully fab’d up. Only thing left to do is to cut and fit some aluminum angle along the bottom edge of the dash.
Feb 11, 2026
P
Pmt133
reacted to
rolmops's post
in the thread
Thinking about making a trailer cover... Opinions wanted.
with
Like
If you jump up to the $200 covers with a 5 year warranty and spray silicone on it every spring you will have exactly what you are...
Feb 11, 2026
Captndrydock
Wiring a 3 wire trim/tilt pump to throttle handle switch
I see your point, probably best the install relays or solenoid. Although the switch still worked on the old boat I removed it from.
Feb 11, 2026
Captndrydock
reacted to
Scott Danforth's post
in the thread
with
Like
The relays are used because of the inrush current of the motor which will take out the switch
Feb 11, 2026
rolmops
Feb 11, 2026
Feb 11, 2026
Captndrydock
reacted to
Chris1956's post
in the thread
with
Like
My '77 Merc used a solenoid on the up circuit only. The PTT control switch was pretty robust, and the wiring was heavier on the down...
Feb 11, 2026
Captndrydock
Thanks Nordin! For now, I think I'll just use the 10 ga cable, I see no reason to add relays or solenoid, just to run a smaller wire. Is...
Feb 11, 2026
Captndrydock
Thanks Jerry! Your comments confirm with other info. I should know, I suppose. This is how I removed two of these units from old boats...
Feb 11, 2026
Cuppy420
I can do that...thanks!!
Feb 11, 2026
M
MikeSchinlaub
I'm not exactly sure what style livewell you have, but many are plastic ones that have machine screws securing them to the casting deck...
Feb 11, 2026
Cuppy420
What do you mean live well bolts? The panel is loose all the way around the live well
Feb 11, 2026
Cuppy420
I now have a magnet and a couple of wedges. Hopefully this will reveal what i'm missing.
Feb 11, 2026
