R
rodsnguns
replied to the thread
1977 70 hp johnson thermostat housing gasket
I only see 1 grommet in the parts breakdown page aside from the ring for the thermostat itself. Should I do the spring and the pressure...
Feb 12, 2026
R
rodsnguns
Feb 12, 2026
R
Make sure the cover is clean and FLAT.----All aluminum castings warp with time.
Feb 12, 2026
tpenfield
I/O (Sterndrive) Conversion to Outboards
perfect :ROFLMAO:
Feb 12, 2026
P
Pmt133
reacted to
Scott Danforth's post
in the thread
with
Like
Ted may be currently contemplating another layer or so of fiberglass......
Feb 12, 2026
reacted to
jbcurt00's post
in the thread
StarCraft Splash of the Year 2025 - Nominations
with
Like
@redneck joe may be only SC to splash
Feb 12, 2026
Feb 12, 2026
A
airshot
2000’s Bayliner 175 I/O
All depends on how it has been maintained, how it will be maintained, you get what you pay for, but many do not need the Queen Mary...
Feb 12, 2026
A
airshot
reacted to
southkogs's post
in the thread
with
Like
In '02 they weren't wood free. But I know that the construction methods had improved by then. My 02 started life as a dock boat up in...
Feb 12, 2026
Captndrydock
Wiring a 3 wire trim/tilt pump to throttle handle switch
Well I'm persuaded and decided to install solenoids. I went with solenoids instead of relays. My best understanding is 3 wire motors...
Feb 12, 2026
Captndrydock
reacted to
jerryjerry05's post
in the thread
with
Like
Depending on how far the wires are ran?? you could use 12g. wire but the 10g would be the best. When they started using the relays, I...
Feb 12, 2026
Captndrydock
Yep, after reading comments here, I decided to run with solenoids. And , yes, that switch could be quite hard to find. I haven't been...
Feb 12, 2026
Captndrydock
reacted to
Mc Tool's post
in the thread
with
Like
Modern 21st century countries use the mm² measurement ...and the metric system 😆. Whenever I see the wire gauge spec I gotta go to the...
Feb 12, 2026
Captndrydock
reacted to
racerone's post
in the thread
with
Like
The " UP " operation requires more current.----More work is being done.
Feb 12, 2026
Captndrydock
That makes perfect sense. I've decided and already ordered solenoids and other parts. Thanks for taking the time to explain!
Feb 12, 2026
