T
tphoyt
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
I got the transom inserts done . . . Here is a picture of the process . . . rolling out each layer to ensure that there are no air...
Feb 12, 2026
tpenfield
replied to the thread
Feb 12, 2026
tpenfield
reacted to
Scott Danforth's post
in the thread
with
Haha
Ted, how many cases of beer will fit in the bilge where the two 6.2's used to sit? Did you figure in the weight of "provisionings" in...
Feb 12, 2026
T
tphoyt
reacted to
in the thread
with
Like
Feb 12, 2026
Feb 12, 2026
M
Mc Tool
Wiring a 3 wire trim/tilt pump to throttle handle switch
How can it go up more times than it goes down ?🙄😁
Feb 12, 2026
tpenfield
Yes . . . But all for a good cause :p My latest estimates, based on the recent changes are Bracket ~ 500 lbs. Hull...
Feb 12, 2026
JeepGuy319
Starts right up sometimes, but other times crank no start
I'll do another compression test when I get home. Thanks for the help, I am hoping it is a simple fix, but it almost never turns out to...
Feb 12, 2026
R
I can not see or touch your motor !----The red lever should be inline with the valve body for normal operation.----If I saw 90 PSI here...
Feb 12, 2026
JeepGuy319
I will re-test compression when I get a chance. I do not have time to pull the head; it was just a cheap boat that I figured would last...
Feb 12, 2026
R
Compression should be about 140 PSI on that motor.----Is red lever in correct position on the primer valve ?----Sounds like the float...
Feb 12, 2026
R
rodsnguns
1977 70 hp johnson thermostat housing gasket
Yep, saw it now. What about the spring and that pressure control valve. Replace ?
Feb 12, 2026
JeepGuy319
Yes, I hold the key the whole time. I am not sure how to test the electric primer valve. That is what I thought it was initially, but I...
Feb 12, 2026
Fishermark
Resealing Alpha Upper
Had to take some time off of this project, but now am back at it. I was prepared to check the rolling torque on this reseal, but I...
Feb 12, 2026
R
????----There are TWO grommets in there !----One for each poppit valve.----One shown in the picture for clarity.----And quantity 2...
Feb 12, 2026
