D
DeepCMark58A
replied to the thread
Nobody fishing?
Feel like an outfitter, have a dozen rods rigged for fishing pike-sunfish-crappie-walleye. 3 depth finders 1 underwater camera all the...
Feb 12, 2026
T
Tim Collie
1991 150B force outboard no spark
Last time I tried to start it it would start but emittely shut off. Herd a sizzling noise from left side of engine now no spark Do they...
Feb 12, 2026
T
tphoyt
I/O (Sterndrive) Conversion to Outboards
I learned about that hard way as a kid. I glassed over an aluminum plate and it delaminated in the first winter and I was living in Fl...
Feb 12, 2026
tpenfield
No, because of temperature coefficients of aluminum vs fiberglass, foam, etc.
Feb 12, 2026
S
ShoalSurvivor
reacted to
alldodge's post
in the thread
Hydraulic Manifold and Anode Installation
with
Like
You don't need the anode if your not installing a Mercathode. There is no drilling involved in any part or the install. The seal p/n...
Feb 12, 2026
A
airshot
Starts right up sometimes, but other times crank no start
You need to locate a " Factory Service Manual" not an aftermarket one. All your adjustments and specs will be there. When cranking...
Feb 12, 2026
A
airshot
reacted to
racerone's post
in the thread
with
Like
I can not see or touch your motor !----The red lever should be inline with the valve body for normal operation.----If I saw 90 PSI here...
Feb 12, 2026
flashback
reacted to
tpenfield's post
in the thread
with
Like
I got the transom inserts done . . . Here is a picture of the process . . . rolling out each layer to ensure that there are no air...
Feb 12, 2026
flashback
reacted to
Scott Danforth's post
in the thread
with
Like
Ted may be currently contemplating another layer or so of fiberglass......
Feb 12, 2026
craig newton
posted the thread
Can't slide the remote into forward gear.
in
Mercury MerCruiser Sterndrives & Engines
1996 Sterndrive 4.3lx 6cyl. 4 barrel carb with Thunderbolt ignition. Alpha one Gen two. Had this out a few weeks ago and it shifted and...
Feb 12, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
Feb 12, 2026
J
jlh3rd
daily music fix
sorry, but it was posted and was curious about an explanation.
Feb 12, 2026
C
Crosbyman
see video
Feb 12, 2026
Scott06
Resealing Alpha Upper
off your drive serial number and look in the manual it usually says XXXX serial and up use this method or similar some detail on it and...
Feb 12, 2026
Looks good, did ya ever think about aluminum plate or honeycomb aluminum plate?
Feb 12, 2026
