Fishermark
replied to the thread
Resealing Alpha Upper
That video from Ted's Marine Repair discusses differences between Alpha 1, Gen 2 drives. The one I am working on is the original "Alpha."
Feb 13, 2026
S
saltchuckmatt
1977 70 hp johnson thermostat housing gasket
Kits typically are more than you need, and I'm speaking generically. Drop the stat is hot water with a thermometer and watch what it...
Feb 13, 2026
Fishermark
I have service manual 14 - and unless I missed it, it only references the newer models with the pressed on bearing and rolling torque...
Feb 13, 2026
LaqueRatt
67 Year Old Head Bolts
One more thing. Maybe this is a contributing factor in why the bolts are seized up. The parting line between the head and motor has a...
Feb 13, 2026
LaqueRatt
Yes, the plug hole is stripped. While adjusting the carb it died and wouldn't start. I pulled the plugs and the one came out along with...
Feb 13, 2026
R
2001 Mercury 90hp Outboard Hard Start
First thing I would do is load test the battery.-----Then take starter apart for inspection and ohm test on armature.----Also test...
Feb 13, 2026
Texasmark
I had a 2002 90. I didn't boat very often and when out for the first time after a long dry spell, It's thirsty. Bulb has to be hard...
Feb 13, 2026
1960 Starflite
outrrive alignment tool
Just my thoughts. I drilled and taped the end of mine to 3/8"- 16 for slide hammer (in case it sticks) and hanging it up with an eye-screw.
Feb 13, 2026
ratdude747
Or better yet, find a buddy (in my case, my boss) who already has it and offers to loan it to you! He got his as part of a set which...
Feb 13, 2026
R
??----You take thing apart.----Inspect.----Order / replace what is needed.----That is the way I have done this work for many years.
Feb 13, 2026
D
DeepCMark58A
Nobody fishing?
Gearing up for Saturday
Feb 13, 2026
D
DeepCMark58A
Nobody fishing?
Those 8" holes get mighty big when you drop something.
Feb 13, 2026
P
Pmt133
reacted to
Lou C's post
in the thread
Thinking about making a trailer cover... Opinions wanted.
with
Like
I bought a Taylor Made custom cover for my F/W about 20 years ago and built a wood frame to support it in snowy winters. It has held up...
Feb 13, 2026
Lou C
Feb 13, 2026
R
rodsnguns
In My particular application, every (kit) listed only comes with the tstat, tstat ring seal , and the cover gasket. Any other internals...
Feb 13, 2026
