T
Tim Collie
replied to the thread
1991 150B force outboard no spark
Isn't the cdi ign what I have on mine 1 box 5 coils. Been replacing cdi box once with new lasted long term then 2 used lasted about 1 yr...
Feb 13, 2026
LaqueRatt
67 Year Old Head Bolts
I agree, probably could have used more heat. I could not get it cherry red. I don't know if that's really possible with alum, is it? Did...
Feb 13, 2026
B
bakerjw
Thinking about making a trailer cover... Opinions wanted.
Mine was a Carver 70018P which is a PolyGuard cover. Very impressed with it.
Feb 13, 2026
A
airshot
Lots of pro's and con's to a cover.....needs to be waterproof yet needs to breath or it causes mold. Wrestled with this for years. Best...
Feb 13, 2026
C
Crosbyman
options options but pulling the head isn't that hard to do , you can clean out built-up carbon in the exhaust section :-) , drill...
Feb 13, 2026
B
bakerjw
reacted to
Lou C's post
in the thread
with
Like
I bought a Taylor Made custom cover for my F/W about 20 years ago and built a wood frame to support it in snowy winters. It has held up...
Feb 13, 2026
A
airshot
Starts right up sometimes, but other times crank no start
Testing or guessing....which one costs more ??
Feb 13, 2026
K
kenny nunez
Can't slide the remote into forward gear.
2 Xs with Bondo. Somehow the shift slider is bound up with the lever. Try to support the lower in a Workmate or between 2 saw horses...
Feb 13, 2026
R
Note----The HELICOIL repair kit that I have repairs that stripped hole WITHOUT removing the cylinder head.---Easy repair for me.
Feb 13, 2026
1960 Starflite
reacted to
Scott06's post
in the thread
The easiest and most precise way to install a gimbal bearing
with
Like
I have used a piece of 3” sch40 pvc pipe almost a perfect match for the OD of the bearing and was laying around the garage
Feb 13, 2026
R
ROY WILLIAMS
reacted to
Fishermark's post
in the thread
Resealing Alpha Upper
with
Like
It seems the correct torque is 85 ft lbs. That seems high. That's what I will do unless someone has a reason to say otherwise. Let me...
Feb 13, 2026
R
When I pick up older motors like that , they come apart for full inspection BEFORE spending any coins on parts.---Powerhead and lower...
Feb 13, 2026
Fishermark
Feb 13, 2026
S
saltchuckmatt
Corrosion and rust from age or abuse really. You have a tough project ahead of you. I purchased an inexpensive 120 volt stick welder...
Feb 13, 2026
Fishermark
Here's the video I referenced earlier.
Feb 13, 2026
