P
Pmt133
reacted to
Lou C's post
in the thread
Thinking about making a trailer cover... Opinions wanted.
with
Like
In take your last nickel NYS, I wouldn't even consider doing that. And, depending on what happens, I may be able to exit this overpriced...
Feb 13, 2026
Lou C
replied to the thread
Feb 13, 2026
P
Pmt133
Ironically we are building a pole barn but... its for vehicle parking. The town with permitting and other requirements managed to turn a...
Feb 13, 2026
P
Pmt133
reacted to
bakerjw's post
in the thread
with
Like
Mine was a Carver 70018P which is a PolyGuard cover. Very impressed with it.
Feb 13, 2026
P
Pmt133
reacted to
airshot's post
in the thread
with
Like
Lots of pro's and con's to a cover.....needs to be waterproof yet needs to breath or it causes mold. Wrestled with this for years. Best...
Feb 13, 2026
dingbat
67 Year Old Head Bolts
https://www.vevor.com/magnetic-induction-heater-c_10315/1kw-magnetic-induction-heater-hand-held-induction-heater-for-bolts-removal-p_0108...
Feb 13, 2026
R
rodsnguns
1977 70 hp johnson thermostat housing gasket
Apparently somebody needed all those parts worse than the motor did.
Feb 13, 2026
reacted to
kenny nunez's post
in the thread
Can't slide the remote into forward gear.
with
Like
2 Xs with Bondo. Somehow the shift slider is bound up with the lever. Try to support the lower in a Workmate or between 2 saw horses...
Feb 13, 2026
R
rodsnguns
Ok, did some diagram research. So naturally all of the missing parts require 2 each. Springs, pressure relief valves, and grommets...
Feb 13, 2026
dingbat
Aluminum doesn't change color when heated. The first indication that your too hot (~660 C) is when the over heated area drips to the floor
Feb 13, 2026
F
Fillmore
reacted to
MikeSchinlaub's post
in the thread
Triton 175 rear deck removal
with
Like
If you're on android, look at the top right of your camera screen. It probably says 64M, tap it and it will change to 12M. It's the...
Feb 13, 2026
dingbat
reacted to
DeepCMark58A's post
in the thread
Nobody fishing?
with
Like
Gearing up for Saturday
Feb 13, 2026
R
rodsnguns
So I need help. It is obvious where the two grommets go because they were in there And I removed them. But I have no idea whether the...
Feb 13, 2026
R
rodsnguns
Okay?So here is an update on my thermostat, housing questions.I've been posting. I took the thermostat housing off And there is no...
Feb 13, 2026
S
saltchuckmatt
reacted to
airshot's post
in the thread
Starts right up sometimes, but other times crank no start
with
Like
Testing or guessing....which one costs more ??
Feb 13, 2026
