tpenfield
replied to the thread
I/O (Sterndrive) Conversion to Outboards
In the 300+ hp range, I don't think there are leftovers. The re-power craze has gobbled them up like bacon & fries.
Feb 14, 2026
T
tphoyt
The number almost always go south. It’s part of the game. But it will be sweet in the end. Are you going for 2025 left overs or fresh...
Feb 14, 2026
Superjetjim
Mercury V6 XR2 - Does this Stator looks bad?
Further update, timing was way out, nearly an 1" off between 25' past TDC and where it needs to be versus where it was set. Hoping...
Feb 14, 2026
tpenfield
The Admiral has been busy doing make-overs on the bathrooms. Fortunately there is one bathroom recently re-done so we have a place to...
Feb 14, 2026
P
Pmt133
1995 Crownline 202BR Restore
I did cleats to screw to then made peanutbutter to put on the stringer tops and cleats to actually hold down the deck. The screws are...
Feb 14, 2026
S
saltchuckmatt
67 Year Old Head Bolts
No, it will not work.
Feb 14, 2026
LaqueRatt
That inductive gizmo sure seems cool to me. 2 hundred bucks though is kind of pricey. With my luck it wouldn't work either. Something...
Feb 14, 2026
Superjetjim
So got to water test her again today with the new coils - we've made some solid progress. Before it would barely run, now she planes out...
Feb 14, 2026
B
beta
Thinking more about the decking now. Question regarding securing the decking. All the edges will be tabbed to the hull, transom and open...
Feb 14, 2026
A
airshot
Thinking about making a trailer cover... Opinions wanted.
Can depend on where you live and how well you read the rules. Years back I built a deck on my home. As long as it was elevated and not...
Feb 14, 2026
B
beta
Glassed in the boards between motor mount and the stinger a few days ago. The void under the board was filled with foam. Pleased with...
Feb 14, 2026
P
Pmt133
They gave a C.O. for my parents house with visible light coming through the joint of the extension to the original house... done by the...
Feb 14, 2026
P
Pmt133
reacted to
Lou C's post
in the thread
with
Like
We got permits for all the major projects we did them being an in ground pool and deck…so when I sell at least that’s covered. The thing...
Feb 14, 2026
tpenfield
Calorifier question?
You might need a right-angle fitting for the hose that connects to the crossover casting.
Feb 14, 2026
Lou C
Feb 14, 2026
