FLATHEAD
reacted to
DeepCMark58A's post
in the thread
Nobody fishing?
with
Like
Well the pike evidently did not get the memo that we were fishing for them yesterday but the crappies bit well, the kids caught a bunch.
Feb 18, 2026
M
Mc Tool
reacted to
dingbat's post
in the thread
Wiring a 3 wire trim/tilt pump to throttle handle switch
with
Like
"Continuous duty" is just that. Circuit stays energized 24/7/365 In your situation, the circuit is only energized when the trim is...
Feb 18, 2026
dingbat
replied to the thread
anyone use the aftermarket p/s actuators sold on ebay and amazon? looking for feedback
Nothing special about rebuilding a hydraulic cylinder. Finding replacement seals is the toughest part if a kit isn't available Simply...
Feb 18, 2026
dingbat
Feb 18, 2026
N
Nordin
The advantage with relays in my opinion is they are cheaper, easier to change and if you are going to mount them under the engine cowl...
Feb 18, 2026
R
581528 is the proper one !!
Feb 18, 2026
Captndrydock
Hones
Feb 18, 2026
Captndrydock
reacted to
Nordin's post
in the thread
with
Like
I would use two regular automotive auxiliary relays (five pin) used for auxiliary lights etc, and two pre wired sockets. These relays...
Feb 18, 2026
N
Nordin
Feb 18, 2026
Captndrydock
Ha, no problem, as far as I can tell it's kind of correct, sort of. Apparently intermittent use is recommended and sold for trim tilt...
Feb 18, 2026
R
Electrical parts are so confusing.----I need to stop giving tips on this stuff !
Feb 18, 2026
Captndrydock
Well, the more I look into this the more confused I get. The one you recommended is intermittent use, but says it's for trim and...
Feb 18, 2026
Captndrydock
Thanks, I'll look into it!
Feb 18, 2026
Captndrydock
reacted to
racerone's post
in the thread
with
Like
BRP--581528---might work.----on Johnson / Evinrude 1975 power trim / tilt systems
Feb 18, 2026
R
Feb 18, 2026
