WIMUSKY
replied to the thread
Trail camera issues fixed, now pics from them ...
Not a wolf this time, but a 'yote....
Feb 18, 2026
WIMUSKY
Feb 18, 2026
WIMUSKY
Still a decent buck around..
Feb 18, 2026
WIMUSKY
Ended up during the cam 180 on the tree. There was a hard pack trail going behind the cam. Got a lot more pix... Mr 1 horn. Looks like...
Feb 18, 2026
Captndrydock
reacted to
dingbat's post
in the thread
Wiring a 3 wire trim/tilt pump to throttle handle switch
with
Like
"Continuous duty" is just that. Circuit stays energized 24/7/365 In your situation, the circuit is only energized when the trim is...
Feb 18, 2026
Captndrydock
reacted to
Nordin's post
in the thread
with
Like
The advantage with relays in my opinion is they are cheaper, easier to change and if you are going to mount them under the engine cowl...
Feb 18, 2026
A
AusFox
Mercruiser 350 MAG MPI
I have replaced the cap and rotor, when cylinder 1 is at TDC the tang is on the number 8 on the dissy housing and I believe that is the...
Feb 18, 2026
Injectors tested and good Later found 1 injector stuck open Replaced that injector and still running rich FT mentioned I could just...
Feb 18, 2026
A
AusFox
Well my battle continues!! After sending the injectors away for a test and service and telling them that if they have any doubts about...
Feb 18, 2026
E
Evinrudej
posted the thread
Quick silver 90w gear oil okay for 60hp
in
Mercury & Mariner Outboards
I have a 1991 mercury 60hp. Can you use quicksilver 90w gear oil instead of 80w-90?
Feb 18, 2026
matt167
2020 DF35A 30hp conversion.
DOH. It was early when I wrote it and I was surfing IPL’s at the same time. It’s an EFI engine. DF25A and the only difference is the...
Feb 18, 2026
9
99yam40
title says change from a 35 to a 30. to change HP I would think you would need to change amount of fuel and air. and maybe timing...
Feb 18, 2026
aspeck
Nobody fishing?
You should come west ... Sayers Lake at Bald Eagle State Park is like "tent city" all winter. It is crazy how many fisher people are on...
Feb 18, 2026
FLATHEAD
Nobody fishing?
Starting with slush on top here. Won’t be long now till the ice fishing guys are done. Was shooting the bull at the local tackle shop...
Feb 18, 2026
FLATHEAD
reacted to
DeepCMark58A's post
in the thread
Nobody fishing?
with
Like
So this morning I demonstrated to the teenagers how to fillet a crappie, left them to their own to clean the 15 fish we kept. They got...
Feb 18, 2026
