A
airshot
replied to the thread
90 Mercury 40HP motor
I have the 1992 version of this outboard, oil injected and never an issue. Yes the magnet came off the float in the oil reservoir so...
Feb 20, 2026
Looking for alignment tools
Search Mercruiser alignment tool, many sell them. They work on Merc, VP and OMC Dimensions of tool
Feb 20, 2026
J
Jeepman252
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
4.3 with Alpha 1, Gen 1 Ok, I have an 89 Sea Ray that the motor decided to spin a main bearing and crack the block. Instead of finding...
Feb 20, 2026
R
Power trim always includes the tilt function.
Feb 20, 2026
L
Lpgc
Swap wood panel in upholstery
The 'old timer formula' seems to have set hard on the replacement wood panel, I don't see a need to give it another coat of varnish now...
Feb 20, 2026
J
-JR-
posted the thread
Honda BF50A. Delayed water cooling discharge
in
Honda & Tohatsu/Nissan Outboards
After launching the boat in the lake and starting it up for warm up, I'm getting no water coming out of the cooling pee hole . But...
Feb 20, 2026
jimmbo
If that motor has Power Trim, it has Power Tilt.
Feb 20, 2026
W
warddog
I have had some local inquiries about parting out this motor but I know nothing about it. The marina stated it had power trim but...
Feb 20, 2026
R
rjcamel2355
99 3.1l ox66 wont rev (what am i not thinking of here)
Little update: Compression test on all 6 checked out, all even. Replaced knock sensor with a new (used) one, that one seemed to work...
Feb 20, 2026
Texasmark
reacted to
Earl Cordova's post
in the thread
Quick silver 90w gear oil okay for 60hp
with
Like
Very little difference between 80w-90 and 90w, so why not ?
Feb 20, 2026
T
TnTommy
Water pressure valve replacement 2000 evinrude 4stroke
I thought it was very odd placement myself and why I’m very hesitant to pull it all apart to replace it that’s a lot of work for...
Feb 20, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
I'm getting close to completing the internal tabbing and related work on the inside of the planing surface. One thing that I had...
Feb 20, 2026
Mercruiser 350 MAG MPI
With it being a reman motor the serial number won't be there. What year is the boat? Jason does bring up a good point about checking...
Feb 20, 2026
T
tphoyt
reacted to
tpenfield's post
in the thread
with
Like
Feb 20, 2026
tpenfield
Feb 20, 2026
