Looking for alignment tools
Jeepman252
4.3 with Alpha 1, Gen 1
Ok, I have an 89 Sea Ray that the motor decided to spin a main bearing and crack the block.
Instead of finding another motor, I found an 89 Larson with the same motor/outdrive that I will use as a donor.
I need the alignment tools for this. Not sure which ones I need.
Will need this pretty soon as I will be starting this project within a month. Gotta wait until a bit of this Wisconsin snow melts and the temps get a bit warmer as this will be an outside project!
Thanks!
Search Mercruiser alignment tool, many sell them. They work on Merc, VP and OMC
Dimensions of tool
alignment-bar-jpg.36979
matt167
Thanks,
Is that the only tool I need? I'll be swapping the entire deal, engine to the prop.
Yes. You won’t need the transom assembly unless it’s in better shape since they are the same. But it would give you a good idea of transom condition if you do
Jeepman252
I will be swapping the transom assembly too, the donor is in better shape.
So, with that, any additional tools?
Ayuh,..... No special tools, just the usual mechanic's tools,.......
Scott06
Thanks!
The guys have you straight with tools needed. Only other thing I would recommend is to check your transom and stringers for rot when you get the old engine out. Give the age of the boat its highly likely you may find some
flashback
I have to ask, what's wrong with the donor If it's in better shape.
Jeepman252
Donor is a 19', floor is tough, gel coat is very tough, seats are tough too.
The Sea Ray is a 21' with a small cuddy which we wanted to be able to spend nights around the Apostle Islands, Lake Superior. The boat is in great shape and is right for the big lake.
Jeepman252
Thanks for that. I've had the engine out and the transom/stringers and engine mounts are all good!
matt167
eBay. It indeed looks like $25 will buy one. I think I gave $50ish 3 years ago
Grub54891
Welcome to the Apostle islands. A 21’ isn’t too bad for the area, but be sure to check the weather often! It changes in a heartbeat! Where do you plan on launching from?
