B
boscoe99
replied to the thread
04 Yamaha 225 4-stroke- -injector harness 2 End Plugs?
You are welcome!
Feb 21, 2026
LaqueRatt
67 Year Old Head Bolts
Hot damn, I got it! On only my 2nd attempt. Welded a washer to the stub, then welded a nut to the washer. Thanks for the tips and moral...
Feb 21, 2026
tpenfield
1994 5L EFI Volvo penta
Wow . . . is this a current boat or a new-2-you boat? It seems like we may have missed a few beats. :unsure:
Feb 21, 2026
B
Boaterdan278michigan
posted the thread
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
Today I wanted to perform a compression check on my Ford 5L EFI engines. I pulled all the spark plugs. When I used the key to turn the...
Feb 21, 2026
ct1762@gmail.com
1977 70 hp johnson thermostat housing gasket
now all you need is the t stat, x2 grommets and the cork t stat round gasket. this is on ebay. tons of springs available. just a thin...
Feb 21, 2026
flashback
Looking for alignment tools
I have to ask, what's wrong with the donor If it's in better shape.
Feb 21, 2026
flashback
reacted to
Scott06's post
in the thread
with
Like
The guys have you straight with tools needed. Only other thing I would recommend is to check your transom and stringers for rot when you...
Feb 21, 2026
tpenfield
Finally. Some warm times.
we still have winter . . . this is the forecast Sunday-Monday . . .
Feb 21, 2026
B
bakerjw
posted the thread
in
Boat Restoration, Building, and Hull Repair
Getting some warm afternoons here and there. Getting a chance to nidacore the hatches on my boat. They were originally constructed with...
Feb 21, 2026
M
Mc Tool
Chinese carbs
The carbs are pretty much identical , probly where the original came from . I have since reamed the air correctors and now the china...
Feb 21, 2026
P
Pmt133
reacted to
airshot's post
in the thread
Been a little cold.
with
Like
You would probably be better off being in your house than being in your boat in that kind of a snow storm !....lol...
Feb 21, 2026
T
TnTommy
Water pressure valve replacement 2000 evinrude 4stroke
I’ve already replaced thermostat I’m talking about the water pressure valve but thanks
Feb 21, 2026
T
tphoyt
reacted to
airshot's post
in the thread
Been a little cold.
with
Like
Feb 21, 2026
T
tphoyt
reacted to
WIMUSKY's post
in the thread
Random
with
Like
Feb 21, 2026
A
airshot
Been a little cold.
Feb 21, 2026
