replied to the thread
Electronic steering
remember, everything man-made will fail the probability that a steel cable in a sheath fails vs a steering system that stops working...
Feb 24, 2026
C
Water pump parts
Amazon likely carries it as well, as do ebasicpower, crowleymarine, iBoats, Marineengine.com, and your local Mercury dealer.
Feb 24, 2026
Texasmark
Electronic steering
Well you have fluid in the system that can apply force where needed even though you need to "grunt" a little if the pump quits. With...
Feb 24, 2026
D
DeepCMark58A
SNOW Common Sense
After the snow be aware walking on ice, do the penguin walk shuffle so you don't fall.
Feb 24, 2026
R
1999 Volvo Penta 5.0 GL freeze plug kits
Agree with post #4.----If pushed out by cold weather then inspection is required.-----They are " core plugs "----And somehow they began...
Feb 24, 2026
D
DeepCMark58A
SNOW Common Sense
That whole sound of whirring blades is an indication you don't put body parts there towards the noise.
Feb 24, 2026
D
DeepCMark58A
reacted to
jlh3rd's post
in the thread
SNOW Common Sense
with
Like
I always clean grass clumps from under my mower with it running, right?...😳...😂
Feb 24, 2026
J
JonBoat55
reacted to
airshot's post
in the thread
Been a little cold.
with
Like
I have always wanted a summer place in the UP of Mich, then a winter place in the south, so I could keep from freezing in winter and out...
Feb 24, 2026
J
jlh3rd
SNOW Common Sense
Feb 24, 2026
B
bakerjw
1981 Springbok 18' Restoration/Renovation
Said as I can't work on my boat because the weather has been too cool for resin work. I love working with glass. ;)
Feb 24, 2026
B
bakerjw
reacted to
SlipperyOar's post
in the thread
with
Like
Sure doesn’t, gives you a headache when trying to minimize warping during welding but I’ll take those struggles any day over the itch of...
Feb 24, 2026
Napa keeps core plug kits in stock. marine use brass or stainless. cars and trucks use coated tin Melling MPE-100BR is for small...
Feb 24, 2026
Superjetjim
reacted to
racerone's post
in the thread
Mercury V6 XR2 - Does this Stator looks bad?
with
Like
Why did they laugh?----If it was warped , how much was it warped?
Feb 23, 2026
Superjetjim
They laughed at how clean the top cylinder was and that corresponded with the areas that were way out of tolerance.
Feb 23, 2026
S
SlipperyOar
reacted to
MikeSchinlaub's post
in the thread
with
Like
Cowards!
Feb 23, 2026
