replied to the thread
was thinking of changing over to a Delco EST system from points....
Lou, ask yourself if the juice is worth the squeeze? how many sets of points will you go thru in the next 20 years? maybe 2? so $30...
Mar 2, 2026
P
Pmt133
From what I've read (been keeping this in the back of my mind for when my TB V eventually dies) the sierra module has a higher failure...
Mar 2, 2026
A
airshot
Repainting a 1989 Crestliner Sabre G/L outboard
Does your boat sit in the water during the boating season or sit on a trailer? No copper paint on an aluminum hull ! If your boat is...
Mar 2, 2026
A
airshot
Getting impatient
Fuel for the motor noises !!!
Mar 2, 2026
dingbat
Nothing special about an ignition module. Simply encapsulated high voltage contact relay(s). You just need a contact to trigger the...
Mar 2, 2026
JimS123
Getting impatient
No Spring work for me. I only maintain in the Fall just before deer season. My annual procedure is to fill up the gas tank just before...
Mar 2, 2026
Lou C
posted the thread
in
Non-Repair I/O and Inboards
And I saw Michigan Motorz selling the complete kit described as...
Mar 2, 2026
Texasmark
Tricks to hold flywheel to tighten nut
Ok change the direction of the impact wrench for another bullshit post!
Mar 2, 2026
R
Check/Fix/Replace Starter Motor 1996 50hp
In my opinion , there is nothing hard about installing the brushes.
Mar 2, 2026
S
saltchuckmatt
Agreed, starter is pretty easy to test and cleanup. Installing the brushes is the hardest part but doable. While spinning and under...
Mar 2, 2026
Mercruiser 350 MAG MPI
I would start looking closer at the IAC and TPS. Basically you gave the motor more air and it fired up First post What where you...
Mar 2, 2026
R
I have the brushes on hand.----Picked up from local starter shop.-$6.00 a set.----Compared to $30 from other places.----These starter...
Mar 2, 2026
C
First source a new starter and some brushes, then try to repair it. ARCO, Sierra and others make replacement starters. Try...
Mar 2, 2026
Bugzilla46310
reacted to
Lpgc's post
in the thread
Trailer wheel bearings - standard or stainless
with
Like
I ended up asking on a Rangerover forum if anyone in the US would be willing to send me some PE2015 1-1/16″SEAL [UFP] [198-138], someone...
Mar 2, 2026
D
DeepCMark58A
reacted to
roscoe's post
in the thread
Port, not larboard.
with
Like
In my boat, I have to speak in plain English. So, it’s..… Honey, no, turn around, this side.
Mar 2, 2026
