R
replied to the thread
Ruh-Roh… a new gear case may be in order
Pinion should fall out.
Mar 2, 2026
JimDirt
Ok I’m at that point but I’m finished for tonight. I haven’t taken the shift rod out yet. Driveshaft is out, but the pinion gear is in...
Mar 2, 2026
JimDirt
reacted to
racerone's post
in the thread
with
Like
Reverse gear should fall out.------Then remove the nut on the bottom of driveshaft.----Remove driveshaft.----Push shift rod to...
Mar 2, 2026
R
Check/Fix/Replace Starter Motor 1996 50hp
Cardboard is a bit of a joke for the tool.----I have used 2 kitchen knives to hold brushes in place while lowering the starter...
Mar 2, 2026
S
saltchuckmatt
I was just looking through the eyes of an inexperienced or super busy op....compared to many starters it's not AS easy. Simple tool is...
Mar 2, 2026
R
Mar 2, 2026
BWR1953
reacted to
lgaytan's post
in the thread
Nobody fishing?
with
Like
Mar 2, 2026
M
Mc Tool
reacted to
lgaytan's post
in the thread
Nobody fishing?
with
Like
Mar 2, 2026
Replacing Bravo 1 lower shift cable
Maybe, but easiest is attach a string to the cable before it's pulled out and than use string to pull it back in
Mar 2, 2026
JimDirt
Edit: I went and back through the beginning and saw racerones post about reverse gear falling out, etc. if racerone, or anyone else sees...
Mar 2, 2026
JimDirt
So here it is. Finally! I had to make some custom tips to get the snap ring out, got started on the 2nd one and the damn thing broke. I...
Mar 2, 2026
redneck joe
reacted to
Mc Tool's post
in the thread
Getting impatient
with
Like
At the boat ramp ? 😁
Mar 2, 2026
redneck joe
reacted to
airshot's post
in the thread
Getting impatient
with
Like
Fuel for the motor noises !!!
Mar 2, 2026
redneck joe
reacted to
lgaytan's post
in the thread
Nobody fishing?
with
Like
Mar 2, 2026
S
ShoalSurvivor
reacted to
achris's post
in the thread
torque for y pipe bolts
with
Like
That is a accepted torque for a 3/8" UNC screw, as per just about any screw torque chart you'd like to consult. (Here's one I prepared...
Mar 2, 2026
