P
Pmt133
replied to the thread
I/O (Sterndrive) Conversion to Outboards
I was under the impression that all plans involve beer?
Tuesday at 9:18 AM
C
wall carpet replacement
Most boats use a marine carpet for places like that. Marine carpet fibers are some form of plastic, which doesn't stain easily and is...
Tuesday at 9:11 AM
flashback
reacted to
Scott Danforth's post
in the thread
with
Like
Plan C involves beer
Tuesday at 9:02 AM
flashback
Plan C gets my vote.
Tuesday at 9:02 AM
F
FishAtFive
1987 50hp Evinrude E50TLCUD Thermostat Replacement
I believe so. If I recall correctly they were between 140 and 150 and +-10% of each other. I checked twice, when I first started working...
Tuesday at 9:01 AM
redneck joe
Random
https://www.facebook.com/share/r/19QdJbEYwC/
Tuesday at 8:54 AM
flashback
reacted to
Bondo's post
in the thread
New engine will not throttle up 350 mag mpi
with
Like
Ayuh,...... Welcome Aboard,...... Lack of fuel killed the 1st motor, so I'd start there,..... Start at the fuel tank...
Tuesday at 8:39 AM
R
Did you ever post the actual compression values on this motor?
Tuesday at 8:28 AM
are you talking carpet or hull liner? many cuddy cabins and express cruisers are lined in "hull liner" I got my hull liner at an RV...
Tuesday at 7:57 AM
O
oldbouy
posted the thread
in
Boat Topics and Questions (not engine topics)
I had a leak in both side windows , water drained into the wall carpet , I sealed the leak , the water damage caused black mold in a...
Tuesday at 7:40 AM
F
FishAtFive
Not even an option, the previous owner did a **** poor job on a through hull and the transom rot is up to one of the four mounting bolts.
Tuesday at 7:35 AM
Tuesday at 7:16 AM
R
Jonsson 235v6 78vm
This thread is a mystery.
Tuesday at 6:49 AM
M
markhodges78
Stator issue ( I believe )
This is from the manual.
Tuesday at 6:08 AM
J
joefran53
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
So after losing my first engine with 700 hrs because of 2 bad injectors I install a rebuilt 350 mag MPI long block. With all original...
Tuesday at 6:06 AM
