A
airshot
replied to the thread
How to kill mold on billge/engine surfaces
Sheesh.....simple and cheap cleaning vinegar works wonders and safe to use. With all the rain and extreme temp swings we have been...
Apr 6, 2026
C
Carbine1964
OK a question. I have a little 1984 Evinrude 7.5 HP.. Beautiful motor.
Yes 80w90, same as I use in my 70HP Johnson. Sorry for calling it grease.. No it is definitely not going to get my 17 foot fishing boat...
Apr 6, 2026
J
jlh3rd
and then there are these out there that have no "specs" what-so-ever. Of course it says guaranteed value so I'd definitely be wrong...
Apr 6, 2026
C
Carbine1964
reacted to
Crosbyman's post
in the thread
with
Like
I did change the lower unit grease and it looked real good. oil hopefully...
Apr 6, 2026
dingbat
spindle/ hub seal tolerance
Depends on the seal and the application. but generally speaking..... Up to 4.0" diameter = ±0.003"
Apr 6, 2026
A
airshot
reacted to
dan t.'s post
in the thread
with
Like
My vote is for cleaning vinegar it has always worked for me, nontoxic.
Apr 6, 2026
A
airshot
reacted to
Chris1956's post
in the thread
with
Like
Gee, Straight bleach has never failed me and usually overperforms. I use any generic bleach I can get for a good price. Stronger...
Apr 6, 2026
B
BrianVT
Old 4hp Evinrude takes a nap
Good info. Thanks all!
Apr 6, 2026
Texasmark
reacted to
airshot's post
in the thread
Mercury Tempest, Turning Point Mach 3 or Michigan Wheel Apollo?
with
Like
If my memory serves me correctly, the rake is what controls bow lift, but you need someone with more prop expertise than I have.
Apr 6, 2026
Texasmark
reacted to
jlh3rd's post
in the thread
with
Like
I prop for the higher end of the manufacturer's recommended max rpm @WOT for the longevity of my engine. Everything else becomes what...
Apr 6, 2026
R
Lower Unit Oil Leak
A pressure test must be done on the drive.
Apr 6, 2026
JimS123
Lower Unit Oil Leak
It smells like oil. I smelled a bottle of gearcase oil and it does not smell like that. I must say that I don't believe it was leaking...
Apr 6, 2026
P
Pmt133
Trailer tires.
I was just saying on my work trailers in general. (Which are 16s and 17s) The ST tires still typically have higher carrying capacity in...
Apr 6, 2026
P
Pmt133
reacted to
Lou C's post
in the thread
Trailer tires.
with
Like
To do that (LT) you need to go up to 16” rims….
Apr 6, 2026
dingbat
Trailer tires.
https://www.americanmadehq.com/carlisle-tires-made-in-usa/
Apr 6, 2026
