J
Jeff J
replied to the thread
Trailer tires.
Tires will generally let a person know when they are going bad and should be changed. A person just needs to actually look at them now...
Apr 9, 2026
O
Ozzy613
reacted to
airshot's post
in the thread
Trailer Set Up
with
Like
That front roller is doing nothing but get in the way. I would add a couple keel rollers to the crossmembers, I am a believer in extra...
Apr 9, 2026
T
TnTommy
Is my motor sitting to low?
I believe it is a hollow bottom
Apr 9, 2026
Texasmark
‘91 merc 60hp hitting wot rpm??
https://www.go-fast.com/Knowledge-base/What-is-Prop-Slip/Prop-slip-calculator: Plugging in 1.64 gear ratio 13P prop 4500 RPM Zero slip...
Apr 9, 2026
rolmops
Boat Cover Repair?
It would be a good time to see if you can find the receipt or the brand that sold you the cover. At least mine , gives a five year...
Apr 9, 2026
Just thought I'd share a nice photo.
They are Gold Finch and redid vid to remove my name
Apr 9, 2026
BWR1953
Cool! What are they? Chickadees?
Apr 9, 2026
LaqueRatt
posted the thread
Boat Cover Repair?
in
Boat Topics and Questions (not engine topics)
Is there any way to save a 2 year old boat cover that has a small rip in it? Thought I'd padded the corners of the windshield well, but...
Apr 9, 2026
R
1983 Evinrude 15 how to remove drive shaft
make an adapter to clamp on the shaft.-----Pull it out with a slide hammer.
Apr 9, 2026
Apr 9, 2026
FLATHEAD
reacted to
BWR1953's post
in the thread
with
Like
I learned that they're very particular about their housing requirements. They want the bluebird house mounted 6 to 8 feet above the...
Apr 9, 2026
P
Pmt133
reacted to
Scott Danforth's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Unlike the Mars rover design team. most engineers use about 3 or 4 units of measure depending on the customer. And get the conversions...
Apr 9, 2026
P
Pmt133
reacted to
BWR1953's post
in the thread
with
Like
I found a couple pix from 2014 showing how much the birds love a good water feature. This feature was set up in our front tree island...
Apr 9, 2026
M
motomanmatt
posted the thread
in
Johnson & Evinrude Outboards
Attempting to replace the impeller on a 1983 Evinrude 15 (E15RCNC). When I drop the gearbox, the drive shaft does not come with it (as...
Apr 9, 2026
BWR1953
Apr 9, 2026
