replied to the thread
I/O (Sterndrive) Conversion to Outboards
I got the idea from an old salty sailor about 15 years ago.
Apr 9, 2026
dingbat
Just thought I'd share a nice photo.
Bluebirds used to flock to our front field back when it was used as a tree nursery. Still see them, just not in the numbers seen before.
Apr 9, 2026
flashback
reacted to
Scott Danforth's post
in the thread
with
Like
Unlike the Mars rover design team. most engineers use about 3 or 4 units of measure depending on the customer. And get the conversions...
Apr 9, 2026
flashback
I've also used the allen wrench trick when mounting hardware on a balsa core deck on my old sailboat, it works well.
Apr 9, 2026
J
jetkit
reacted to
alldodge's post
in the thread
1999 Mercruiser 4.3 cool fuel pump pressure
with
Like
Thanks for the update and good to here your up and running Dead heading a fuel pump should not damage it, Merc even has a test...
Apr 9, 2026
R
Is my motor sitting to low?
Pontoon boats are different;-----Test run and post what happens.----Or why the concern?
Apr 9, 2026
M
mike_i
Boat Cover Repair?
I tried the iron on patches once but they eventually peeled off.
Apr 9, 2026
frustratedboater
posted the thread
Timing Q w/ 07 Suzuki df250z 4-stroke
in
Yamaha & Suzuki Outboards
Greetings, I have a timing issue with my 2007 Suzuki df250z 4-stroke and wanted to clarify with you all on a particular step in the...
Apr 9, 2026
S
saltchuckmatt
Ruh-Roh… a new gear case may be in order
Yes, more than enough.
Apr 9, 2026
J
Jeff J
Trailer tires.
Tires will generally let a person know when they are going bad and should be changed. A person just needs to actually look at them now...
Apr 9, 2026
O
Ozzy613
reacted to
airshot's post
in the thread
Trailer Set Up
with
Like
That front roller is doing nothing but get in the way. I would add a couple keel rollers to the crossmembers, I am a believer in extra...
Apr 9, 2026
T
TnTommy
I believe it is a hollow bottom
Apr 9, 2026
Texasmark
‘91 merc 60hp hitting wot rpm??
https://www.go-fast.com/Knowledge-base/What-is-Prop-Slip/Prop-slip-calculator: Plugging in 1.64 gear ratio 13P prop 4500 RPM Zero slip...
Apr 9, 2026
rolmops
Boat Cover Repair?
It would be a good time to see if you can find the receipt or the brand that sold you the cover. At least mine , gives a five year...
Apr 9, 2026
They are Gold Finch and redid vid to remove my name
Apr 9, 2026
