  • dingbat
    dingbat reacted to FLATHEAD's post in the thread Trailer tires. with Like Like.
    The Kenda Karriers arrived and are on the trailer. Tomorrow I head to the lake. Glad I got new when I did because I found a small nail...
  • bruceb58
    bruceb58 replied to the thread Trailer tires..
    Defenders are the only tires I use. When my Rivian's Pirellis wear out by the end of this year, Defenders are going on the car. Same...
  • bruceb58
    bruceb58 reacted to dingbat's post in the thread Trailer tires. with Like Like.
    Just had a third set of Defender 2 on my daily (Civic) last week. Got 63k out of the last set. Put upper 50k’s on the previous two...
  • dingbat
    dingbat reacted to Chris1956's post in the thread VRO Pump Question with Like Like.
    Gee, I always liked my OMS system. You get a fresh gas-oil mix all the time. The motor always idles and runs smooth. I replaced the...
  • 8
    83bluefin replied to the thread 1983 Blue Fin 16’ Resto.
    Started the other night on the trailer. Redneck heaven I swear. Connections with wire nuts, duct tape, and spade connections. It’s a...
  • 8
    Picked up a definite project boat off Faceplant Marketplace. Boat, 50HP Johnson, and Calkins trailer package. Probably one of the...
  • FLATHEAD
    FLATHEAD replied to the thread Trailer tires..
  • dingbat
    dingbat replied to the thread Trailer tires..
    The OE GY Wranglers aged out and where replaced. Guessing these Defenders will too since we average 7K miles a year on the truck...
  • FLATHEAD
    He got another grey squirrel. This fox is a good hunter. 😎
  • A
    Before spending money, is the motor performing at its peak ? Make sure carbs are wide open. Buy a cheap portable tech and see if your...
  • A
    airshot reacted to jimmbo's post in the thread ‘91 merc 60hp hitting wot rpm?? with Like Like.
    Before you go spending any money on Props, what condition is the Engine in? Have you done a Compression Test? If yes, what are the...
  • A
    airshot replied to the thread Is my motor sitting to low?.
    Can't tell much from the pics....
  • A
    airshot reacted to Lou C's post in the thread Trailer tires. with Like Like.
    I think that's common, the rubber is starting to oxidize and dry out and becomes stiffer, so you lose grip. Especially noticeable in wet...
  • A
    airshot reacted to Pmt133's post in the thread Trailer tires. with Like Like.
    Michelin defenders. Expensive but seem to be one of the few I get my money's worth out of. Had a set of hankook tires on my 04 that went...
  • A
    airshot replied to the thread Boat Cover Repair?.
    While it won't be pretty, get a piece of heavy fabric and some flexible water proof glue. Glue a patch to cover the tear and spread the...
