P
Pmt133
replied to the thread
I/O (Sterndrive) Conversion to Outboards
Maybe use epoxy so you get a longer working time too?
Apr 10, 2026
P
Pmt133
reacted to
Scott Danforth's post
in the thread
with
Like
Ted, I would assemble the two parts with PB between the two. You are not going to remove the extension, so make it permanent Boat...
Apr 10, 2026
K
Kwanza
Alternator and fuel pump on Volvo Penta 3.0 GLP-D
Thank you. I'll keep checking, and will clean other connections as well. Will attempt disconnecting the bilge blower, to see if that...
Apr 10, 2026
P
Pmt133
Scott seemed to have the worse of the issues than I did. But I'll tell you what I got. On the 330 we ran a bead of 5200 around the...
Apr 10, 2026
No dipstick on 1989 era 3.0L?
Rotella T4 15w-40 diesel
Apr 10, 2026
Pushing Run-Flat tires to the limit
Most BMWs down here also don't have working turn signals..... Or at least the blue hair behind the wheel forgot how to use them
Apr 10, 2026
Apr 10, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
Looking ahead . . . the test fit is also serving as a rehersal of the actual installation process. My plan is to . . . Position the...
Apr 10, 2026
P
Pmt133
reacted to
in the thread
with
Like
smear a bit of blue or yellow snap-line chalk on the boat hull surfaces. then look for transfer to the extension
Apr 10, 2026
C
1987 Mercury Black Max XR2 150hp - Stator Testing
A Factory service manual might be the way to go. Although the ADI ign systems on the V6 engines are common from 1978 to the late...
Apr 10, 2026
D
DeepCMark58A
Paintball gun
No goose control, no rodent or dog.
Apr 10, 2026
D
DeepCMark58A
reacted to
in the thread
Paintball gun
with
Like
back in the late 90's I worked at a company where 3/4 of the machine shop were in a paint ball club. they made gatling gun paint ball...
Apr 10, 2026
10W40 diesel oil
Apr 10, 2026
There is a bad connection somewhere My thought is that the wire would be close to the end of the tubing. Try looking at the other end...
Apr 10, 2026
tpenfield
Apr 10, 2026
