J
jlh3rd
replied to the thread
Lower Unit Oil Leak
I just think you had some anomaly. A one time thing. Oil got spilled or something. If the engine drive shaft area is leaking, you'd...
Apr 10, 2026
flashback
Pushing Run-Flat tires to the limit
that's not particularly a regional problem! :)
Apr 10, 2026
reacted to
roscoe's post
in the thread
Stuck floor board over gas tank on Alumacraft
with
Like
screw 2 eye screws into it, on opposite sides, attach rope, and pull up.
Apr 10, 2026
flashback
reacted to
Scott Danforth's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Ted, I would assemble the two parts with PB between the two. You are not going to remove the extension, so make it permanent Boat...
Apr 10, 2026
aspeck
Just thought I'd share a nice photo.
We have surface temps in the low 50's also. Lakers are running at the 20'-40' depth I am told. Haven't had a chance to chase them yet.
Apr 10, 2026
A
airshot
reacted to
piperjoe's post
in the thread
1973 Starcraft SuperSport 16ft. restoration questions
with
Like
It’s 38 degrees right now and the snow is about 80% gone. Forecast is saying it will be in the 50’s - 60’s starting tomorrow and...
Apr 10, 2026
A
airshot
reacted to
JimS123's post
in the thread
Trailer Set Up
with
Like
You definitely need a bow eye. That setup with the eye up that high is certainly odd. I like the idea of the bow roller, but it needs...
Apr 10, 2026
A
airshot
reacted to
roscoe's post
in the thread
Trailer Set Up
with
Like
Just buy a new appropriate (taller) winch post and winch. No sense in trying to make that one work, it is used up.
Apr 10, 2026
R
1987 50hp Evinrude E50TLCUD Thermostat Replacement
See post #2
Apr 10, 2026
JimS123
Lower Unit Oil Leak
I wiped the oil when I started this thread. Hasn't seeped a drop since.
Apr 10, 2026
JimS123
Trailer Set Up
Apr 10, 2026
JimS123
Boat Cover Repair?
I ripped a cover once. It was brown cotton twill canvas. My wife's standard sewing machine handled it nicely. She stitched across the...
Apr 10, 2026
tpenfield
The extension bracket is fitting better. I think a 1/2" spacer will do the trick. . Here is the starboard side . . The port side seems...
Apr 10, 2026
K
Kwanza
reacted to
MarineSp's post
in the thread
Alternator and fuel pump on Volvo Penta 3.0 GLP-D
with
Like
The blower dropping voltage from 14V to 12V is a big clue. That means the alternator cant handle even a small extra load — which points...
Apr 10, 2026
88 Capri (2022 SOTY)
1989 omc cobra gear case problem
The pinion gear is drawn up the splined tapered shaft, if it's not tight enough it could possibly cause your issue.
Apr 10, 2026
