FLATHEAD
replied to the thread
Just thought I'd share a nice photo.
Stripers are in the Delaware River right now. They follow the shad up. Buddy has a jet , might jump on an invite to chase some tomorrow.
Apr 10, 2026
M
MarineSp
Power steering fluid in bilge?
Todd, given the brutal cold you described, I'd also check the fittings where the hoses connect to the helm and the ram – those can...
Apr 10, 2026
M
MarineSp
Noise after replacing impeller and fuel/water separator
That rhythmic brushing sound is almost certainly the impeller itself. Most likely causes: Impeller blades installed backwards (they...
Apr 10, 2026
B
boscoe99
Need help with ID
Apr 10, 2026
B
boscoe99
Need help with ID
Apr 10, 2026
redneck joe
With the way my life is moving atm im prob not going to get on the water until after 4 July.
Apr 10, 2026
J
jlh3rd
Lower Unit Oil Leak
I just think you had some anomaly. A one time thing. Oil got spilled or something. If the engine drive shaft area is leaking, you'd...
Apr 10, 2026
flashback
Pushing Run-Flat tires to the limit
that's not particularly a regional problem! :)
Apr 10, 2026
reacted to
roscoe's post
in the thread
Stuck floor board over gas tank on Alumacraft
with
Like
screw 2 eye screws into it, on opposite sides, attach rope, and pull up.
Apr 10, 2026
flashback
reacted to
Scott Danforth's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Ted, I would assemble the two parts with PB between the two. You are not going to remove the extension, so make it permanent Boat...
Apr 10, 2026
aspeck
We have surface temps in the low 50's also. Lakers are running at the 20'-40' depth I am told. Haven't had a chance to chase them yet.
Apr 10, 2026
A
airshot
reacted to
piperjoe's post
in the thread
1973 Starcraft SuperSport 16ft. restoration questions
with
Like
It’s 38 degrees right now and the snow is about 80% gone. Forecast is saying it will be in the 50’s - 60’s starting tomorrow and...
Apr 10, 2026
A
airshot
reacted to
JimS123's post
in the thread
Trailer Set Up
with
Like
You definitely need a bow eye. That setup with the eye up that high is certainly odd. I like the idea of the bow roller, but it needs...
Apr 10, 2026
A
airshot
reacted to
roscoe's post
in the thread
Trailer Set Up
with
Like
Just buy a new appropriate (taller) winch post and winch. No sense in trying to make that one work, it is used up.
Apr 10, 2026
R
1987 50hp Evinrude E50TLCUD Thermostat Replacement
See post #2
Apr 10, 2026
