C
replied to the thread
89 force tilt and trim valve body
Force was bought by Merc, and had Merc gearcases and electronics, at least. Any idea if the valve body is Merc or Chrysler...
Apr 11, 2026
Pushing Run-Flat tires to the limit
Florida requires turn signals https://www.flsenate.gov/Laws/Statutes/2012/0316.155
Apr 11, 2026
R
rossbar86
Noise after replacing impeller and fuel/water separator
I just started it up and it sounded fine at first, then the sound came back. It almost sounds like it is coming from the power steering...
Apr 11, 2026
rolmops
Which kicker mount to install?
And don't forget to make sure that you have some serious backing under the flat surface to prevent the kicker from damaging that surface.
Apr 11, 2026
Stuck floor board over gas tank on Alumacraft
Most likely zip screws were used Once all the fasteners are out of the floor, it will just raise up. But pretty sure the vinyl must be...
Apr 11, 2026
C
No dipstick on 1989 era 3.0L?
If the QS 25W-40 is NA, you can use SAE 30 detergent motor oil, for moderate climates. You also might look at the OEM recommendations...
Apr 11, 2026
Power steering fluid in bilge?
Could be a bad return line Could be a bad pressure line Could be a bad clamp Could be a bad reservoir Could be a leaking actuator...
Apr 11, 2026
rolmops
Mmmm, interesting.... When inserting the impeller, use some form of lubrication (soap) and turn the impeller forward in the direction of...
Apr 11, 2026
A
airshot
reacted to
Pmt133's post
in the thread
with
Like
That's not just a Maryland thing. I'm pretty convinced directionals in general are just an option. That beings said, it's on the book...
Apr 11, 2026
A
airshot
reacted to
FLATHEAD's post
in the thread
Trailer Set Up
with
Like
You can make that work with some $ and time. If it was mine I’d get rid of the rear roller. That boat has plenty of support on the bunk...
Apr 11, 2026
Horigan
Impeller blades self-orient to proper direction, so you don't need to worry about which direction they go in, assuming you installed the...
Apr 11, 2026
D
DeepCMark58A
reacted to
bajaman123's post
in the thread
Paintball gun
with
Like
Empire Mini Axe is consistently rated best...
Apr 11, 2026
Lou C
Agreed on all these possible leak sources. When you can start it up and cycle the steering back and forth, you'll be able to tell...
Apr 11, 2026
C
Crosbyman
1987 50hp Evinrude E50TLCUD Thermostat Replacement
Those power packs seem to be a frequest suspect...maybe heat related.. when the problem comes up you could try a freeze spray to see if...
Apr 11, 2026
F
FishAtFive
Guys in a thread from last year you suggested the same, and you were correct! I did totally break down thr carbs and cleaned ALL the...
Apr 11, 2026
