Fun Times
replied to the thread
Can't change password
Hi there, well unfortunately we have discovered that the websites internal inbound and outbound email system are inoperative in-turn...
Apr 12, 2026
Sprig
Ideas for planters/raised beds?
Wood isn’t expensive for what you’ll need. . Get some 2”x8”x10’ lumber and some 4x4s for the corners and you can slap together a few...
Apr 12, 2026
Lou C
reacted to
Pmt133's post
in the thread
why is there oil in my bellows but pressure test holds 15psi overnight
with
Like
I've seen cheap grease look like lube in the bellows too. Flung and burned down from the gimbal and u-joints. I agree with the...
Apr 12, 2026
Lou C
Smell what you found there. Because if you have a grease-able gimble bearing sometimes the grease will separate out in a runny...
Apr 12, 2026
A
airshot
Which kicker mount to install?
While not easy, some how you need to access the underside of that flat surface as that would be the easiest area to attach a mount. One...
Apr 12, 2026
TSC and rual king have 40 gal tanks for 179
Apr 12, 2026
A
airshot
Stripped drain plug
Is it a bronze plug ? If so, re tap the hole a size larger if threads are totally gone, the n get a bigger plug if there is enough...
Apr 12, 2026
A
airshot
reacted to
Chris1956's post
in the thread
Stripped drain plug
with
Like
Garboard drain fittings are avail. A couple of thru bolts and some silicone could install it.
Apr 12, 2026
A
airshot
Boat Cover Repair?
Can't remember the name ( heck, can't remember my own) but there is a product for repairing tents, a glue on patch product that I have...
Apr 12, 2026
A
airshot
reacted to
Pmt133's post
in the thread
Pushing Run-Flat tires to the limit
with
Like
The old maintain flow of traffic. During rush hour I've been passed doing very illegal speeds. Like lose you license immediately speeds...
Apr 12, 2026
A
airshot
reacted to
dingbat's post
in the thread
with
Like
Maryland law goes one step beyond….you must travel in the right lanes if traveling 10 mph below the flow of traffic and you can’t...
Apr 12, 2026
further
posted the thread
Metal O-Ring appeared on alignment tool
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
Hi all, Long time…. 2004 5.0 GXI SX-M. Getting it ready for the season and doing alignment check. When I pulled out the bar, I noticed...
Apr 12, 2026
D
DeepCMark58A
Boat Cover Repair?
Tear mender, same principal, stuff works.
Apr 12, 2026
230 Mike
reacted to
jbcurt00's post
in the thread
with
Like
@tpenfield @Fun Times
Apr 12, 2026
D
DeepCMark58A
reacted to
WIMUSKY's post
in the thread
Just thought I'd share a nice photo.
with
Like
Me with a pompano. Ignore me...😳
Apr 12, 2026
